Suspension options
Started by VXL V6, 03 February 2016, 21:21:25
I think, if I was always loading up my boot as the OP has intimated, I'd want higher riding springs. Most of the time, I have just the LPG tank in the back, and it's fine. Fully load the car, or put some load on the towbar, and it drags its' @rse on speedbumps and uneven ground.
Facelift MV6 setup does handle nicely, though, especially when lightly loaded.
So, something with MV6 ride height but stiffer, or standard ride height but stiffer than Elite SL, + decent shocks, I reckon.
Quote from: Kevin Wood on 04 February 2016, 15:26:59Facelift MV6 setup does handle nicely, though, especially when lightly loaded.
Agreed, MV6 setup with polys is a good setup.
What about spring assistors in the MV6 Springs, although I'd be a little concerned of weakening them by altering the load bearing characteristics?
Quote from: VXL V6 on 04 February 2016, 18:09:12
Yes, guessing MV6 springs will have to be 2nd hand by now, meaning they might be getting fragile without any "assistance". :-\
Quote from: Kevin Wood on 04 February 2016, 19:46:48
These springs I bought brand new about 18 months ago (When VX could still get you a set from Germany - I think I had the third last set), they've done around 50K.
Another thought is, Chris Gixer used to recommend placing a second spring rubber pad with the centre cut out over the original to get an extra bit of height from -30mm Irmscher / Steinmetz / Eibach springs, I wonder if this would be an option with the MV6 springs?
Thanks to all contributing to this thread - it's all good information and ideas coming through.  :y
tigers_gonads
Don't know if you have a estate or saloon but on my estate, I fitted this lot.
Front  Standard Mv6 springs / B4 shocks / poly wishbone bush.
Rear   LSC standard length heavy duty springs / B4 shocks / Oem bushes.
I did this due to the LPG tank partially behind the rear axel (spare wheel well) and 1 adult / friggin big dog OR boot full of tools / cable.
I found that with about a 1/3 tank of petrol and about 45ltrs of lpg in there, it sits perfectly level and even with the burger van tied to the back, its only about 2 inches down at the back.
Quote from: VXL V6 on 04 February 2016, 20:13:53
Yep, spacer might be the best option. Can't see it stressing the spring and it will give a little more ride height.
You can get poly pads for the Monaro... Nolathane or White line iirc :-\ Might be a bit more durable than 12 year old rubber...
QuoteDon't know if you have a estate or saloon but on my estate
Saloon :)
QuoteYep, spacer might be the best option. Can't see it stressing the spring and it will give a little more ride height.
Yeh that's my thinking too, the assistor would have altered the dynamics of the spring too much I think :y
QuoteYou can get poly pads for the Monaro... Nolathane or White line iirc :-\ Might be a bit more durable than 12 year old rubber...
Like the sound of that, when you look at the rubber pads the indent of the spring pigtail is obvious.
Worth giving Monkfish a call :y
Quote from: VXL V6 on 04 February 2016, 21:34:42
These appear to be the ones I think. need to give them a call to confirm.  :y
http://www.monkfishperformance.co.uk/spring-insulator-rear-10mm-monaro-and-vt2-to-vz-commodore-models_p23023392.htm
Better call them and confirm and place an order I guess!
