Author Topic: Headlight problems  (Read 4370 times)
Tony H
  • liverpool
  • Black Elites are luurvley
Headlight problems
« on: 03 February 2016, 21:57:16 »
Hi all nearside headlight was just shining a pink on monday, this evening went out altogether and a warning came up on the MID. Is it just a bulb problem or something more complexed. Advice needed please.
TIA
Tony
    • 530D M Sport, 330i Coupe
Re: Headlight problems
« Reply #1 on: 03 February 2016, 21:58:21 »
HID Bulb needs replacing if pink.
« Reply #2 on: 03 February 2016, 22:01:26 »
A doddle to change, but unit needs to come out :y half hour job including tea ;)
« Reply #3 on: 03 February 2016, 22:15:33 »
HID bulb failing. If you can, replace the pair (unless other is new), as they do degrade quite noticibly.  I prefer Phillips or Osram, approx. 4200k temp. Quality bulbs are about £30 each, cheaper ones are Chinese fakes, and may or may not be much good.
units can stay in place, but airbox and battery will need to come out.
« Reply #4 on: 03 February 2016, 22:44:38 »
Suggested removing for two reasons... firstly, unplugging and removing allows time to ensure the ballasts are inert. Secondly, it's easier as you've three small screws to remove to get to the back of the bulbs and if you drop one, you'll be pulling the unit anyway ::) so no point opposing about...
« Reply #5 on: 03 February 2016, 22:48:00 »
Is Tony's car face lift or not? Prefacelift with headlight washers need the bumper removing or at least moving forward to allow removal of headlight
« Reply #6 on: 03 February 2016, 22:52:34 »
Remember it as a Facelift :-\
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #7 on: 04 February 2016, 15:18:19 »
I can't recall having to remove anything to replace damaged headlight unit on my facelift.
« Reply #8 on: 04 February 2016, 15:59:28 »
« Reply #9 on: 04 February 2016, 17:29:41 »
you didn't Bill  ;) ;)
Tony H
  • liverpool
« Reply #10 on: 04 February 2016, 19:50:35 »
Hi everyone my Omega is a face lift can any one give me the "heads up on the best pace to buy new bulbs ?
« Reply #11 on: 04 February 2016, 21:10:11 »
D2s from hids4u on ebay... Only by Osram or Philips and 4300k :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #12 on: 05 February 2016, 09:16:50 »
best pace to buy new bulbs ?   Fast :y
« Reply #13 on: 05 February 2016, 14:50:18 »
Halfords, motor factors or ebay ;)
Does rather depend which bulbs though as buying xenons from halfords is a mugs game...
Tony H
  • liverpool
« Reply #14 on: 06 February 2016, 21:28:49 »
 ;D ;D ;D :y
