Author Topic: whats the best way to diagnose this fault ?  (Read 5686 times)
amazonian
  • upper beeding. west sussex
    • 03 2.2 CDX auto estate
« on: 04 February 2016, 23:52:10 »
2003 2.2 CDX.
Everything works as it should, BUT once it gets to about 40mph there begins a low booming resonance accompanied by a slight vibration, which continues up to about 55mph and then appears to die away, although due to tyre and wind noise may just be muffled.
The steering wheel does not shake, it does not feel like wheel balance and it does not alter if I take left/right hand bends, if I am accelerating or on the overun, or if it is in neutral.
It does not happen if its parked and the engine is reved up.
So, possibly discounting wheel balance, wheel bearings, engine mounts, how do I go about diagnosing the rest of the moving parts?
What would you do asuming you could not crawl about under a car yourself !
Re: whats the best way to diagnose this fault ?
« Reply #1 on: 05 February 2016, 00:12:13 »
About the only option is to Jack it up on stands and pop it into gear... Not ideal by any stretch... A two post left is a safer bet...
That said, we need to sort your oil change at some point, so could have a look see then ;)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #2 on: 05 February 2016, 00:13:02 »
Engine or gearbox mounts ?
Presumably propshaft or diff would cause a noise or similar from a standing start.  :-\
« Last Edit: 05 February 2016, 00:17:09 by Migv6 »
amazonian
« Reply #3 on: 05 February 2016, 00:20:44 »
Evening Al,
Oil change would be good, whenever you have time.
Maybe you could run it up the road whilst you are at it and see what you think then.
Cheers
« Reply #4 on: 05 February 2016, 00:22:21 »
Monday lunchtime any good?
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #5 on: 05 February 2016, 00:33:23 »
maybe rear wheel balance. cheap option to check anyway. you could even just swap the wheels round, if they are out the steering wheel will then vibrate.
occurring in neutral as well as in gear indicates it's not an engine or gearbox issue i would think.
amazonian
« Reply #6 on: 05 February 2016, 00:34:09 »
bugger, I have to go to an auction on monday Al.
« Reply #7 on: 05 February 2016, 00:37:22 »
I'm thinking tyre related too...
« Reply #8 on: 05 February 2016, 00:37:59 »
Ok, Thursday?
amazonian
« Reply #9 on: 05 February 2016, 00:38:21 »
Migmog, thanks for replies, I certainly hope you are right about the gearbox .
amazonian
« Reply #10 on: 05 February 2016, 00:40:59 »
Thursday can do Al, thank you.
« Reply #11 on: 05 February 2016, 01:07:10 »
See you then then ;)
K_V6
  • Spain
    • Omega y22dth/Vectra let
« Reply #12 on: 05 February 2016, 19:36:51 »
How long time have wheels? It's probably they are hard as a rock
From Spain. Sorry for my English
  • Auckland
    • Mazda MPV
« Reply #13 on: 05 February 2016, 20:34:10 »
Exhaust perhaps?
Are all the mountings present and correct?
Has anyone been to xxx-fit and had a nasty exhaust fitted?
amazonian
« Reply #14 on: 05 February 2016, 23:14:50 »
How dare you accuse me of going to ........them!!!
I demand an immediate apology.
 :o :o
