Author Topic: whats the best way to diagnose this fault ?  (Read 5694 times)
omega2018
    • MercCL500 Omega2.6ManElit
Re: whats the best way to diagnose this fault ?
« Reply #15 on: 06 February 2016, 00:33:32 »
if its happening just the same at same speed in neutral with the engine at idle then that probably rules out the exhaust as well as engine and gearbox.  you could try switching the engine off but i never said that 8) and don't - it won't give you much more information and it's not safe (not least loss of power steering and braking)  :'(
amazonian
  • upper beeding. west sussex
    • 03 2.2 CDX auto estate
« Reply #16 on: 06 February 2016, 00:39:23 »
As you rightly surmise I certainly wont be trying that at 50mph !
 :o
« Reply #17 on: 06 February 2016, 00:59:22 »
Be a fairly efficient way of trashing the gearbox too...
« Reply #18 on: 06 February 2016, 09:29:11 »
My initial thoughts would be wheel/tyre related as well, probably fronts given the speeds. 2nd thought would be movement in the steering/suspension.
amazonian
« Reply #19 on: 06 February 2016, 16:54:25 »
I sort of discounted the tyres as I had 2 new ones put on the front a few weeks back and I am pretty sure that the problem existed before then.
Harris teletaxi will have a look next week hopefully.
