Author Topic: Cooling fans  (Read 1885 times)
Ulap31
  • welwyn garden city
    • 3.2 elite estate
Cooling fans
« on: 06 February 2016, 13:14:50 »
3.2 litre elite estate auto
Seems my fans both run at one speed how do I do the test to confirm a fault with relay or sensor as after looking on the forum seems they should run at different speeds depending on temperature or a/c running etc.
The 2 front fans also don't turn off once they've cooled the engine down but turn off once ignition is turned off.
Re: Cooling fans
« Reply #1 on: 06 February 2016, 14:49:19 »
There's a guide :y
Go to Maintenance Guides, click on index and scroll down ;)
I'm sure someone will helpfully provide the link, but looking will give you an idea of what's on offer... :y
Front fans will run permanently if the climate panel is on and NOT displaying ECO... ie aircon on
Ulap31
    • 3.2 elite estate
Re: Cooling fans
« Reply #2 on: 06 February 2016, 15:28:34 »
I should have stuck to my 2.5 litre was not as complicated as the 3.2
Cheers for the info
Re: Cooling fans
« Reply #3 on: 06 February 2016, 16:42:41 »
Cheers for the info
All facelift fans should work in the same way ::)
Ulap31
    • 3.2 elite estate
Re: Cooling fans
« Reply #4 on: 06 February 2016, 19:44:59 »
Cheers fans are working as they should that's one less problem to worry about
Re: Cooling fans
« Reply #5 on: 06 February 2016, 21:18:34 »
