Omega wiper blades
Started by tigers_gonads, 13 February 2016, 10:58:17
Quote from: TheBoy on 14 February 2016, 09:04:05
Quote from: BIGtime on 14 February 2016, 00:43:06
Quote from: TheBoy on 13 February 2016, 17:26:47
The other thing, I've snapped 4 or 5 passenger side aeros now, poxy things.  Downside of using them on cars not designed with aeros in mind (along with poor performance).
your just too heavy handed...
Every one I have snapped from the driver's seat ;)
Apart from one, they don't snap off and fly into the following traffic, its "spine" breaks, leaving it attached but floppy.  They always snap in the same place - just outboard of the fixing, passenger side - which makes me wonder if its due to the screen shape.
I will add, I use aeros on the Zafira, and on that flatter screen, they are very good.
Its simply the Omega screen shape means they are substandard (happy, Mr Lazydocker? ;D) on Omegas, in comparison to traditionals.  Remember, I am comparing like with like (having 2 Omegas), not comparing a new aero against a shagged out old blade ;)
:D :D
All down to opinion really. As you know, I have also had new GM and new Aeros very close together and I still prefer the Aeros :y
It would be boring if everyone was the same
EMD
Got a set of standard blades off ebay for £8 , unbranded and have been the best ive used . This is the second set ive used , usually last a good 2 yrs  :y Tried the flat blades and they work for a while then they start making squeaky noises and stop clearing the screen  :(
Omegatitis
FICKIN WIPER BLADES,!!!! Get a life.
Quote from: EMD on 15 February 2016, 13:27:12
Sounds pricey for 2. When we had the Rover (as it was properly designed, thus all 3 blades the same length), I used to buy a pack of 10 GM ones for £20 from dealer, use 3 on the Rover, sell 1 set of 3 on egay for a tenner, and 2 sets of 2 for £7.50.  So not only did I make money off the pondlife that think egay is cheap, I also got free blades for the little Rover.
omega2018
coincidentally my pair arrived today and have just fitted them.  £3.75 a pair yes that's £3.75 for two not each and includes delivery.  from apwipers.com via ebay.  the 19" one came with a spoiler which was unexpected but i transferred it to the 24".  standard wipers, they look fine and fitted well i will report back on performance. perhaps not a fair test as my windscreen is old and slightly scored.
what really wears out the omega wipers i think is that the screenwash only sprays onto the screen after one dry wipe.
Viral_Jim
I've noticed that my passenger side wiper (ordinary wiper blades on a FL estate) occasionally catches the inner edge of the bonnet, usually when travelling at motorway pace with the wipers on full chat. Anyone else experienced this?
I know the car's never been in an accident so no way the bonnet's moved, feels like the passenger side wiper is a few mm too long maybe? but then again it came from a set that's supposed to fit the car  ::).
biggriffin
Got Halfords own brand on, don't lift off at 70mph, also rain-x screen. Job done.
Use to only fit GM but haven't got a tc lokal anymore so Halfords it was, think the lord opti gets his frim ecp £2.50  pair delivered m. 8)
Hoof'land storeman.
Quote from: jimmy944 on 17 February 2016, 13:49:34
Either / or / and:-
Park adjustment is wrong - check the quide on here
Wiper motor bearings collapsing - too much play
Wiper arm set slightly too low - be careful repositioning it as it's possible to tangle up with the drivers side
Wiper drive rod joints are worn - You can buy new ones from Wipex, but, while they solved the problem on mine and the wipers were much more positive etc they where far to tight and when I tried to remove them to re-grease them they just snapped.
omega2018
Quote from: migmog on 16 February 2016, 01:16:27
i have to report that these are great or at least the combination of the new wipers and g5 treatment.  one small thing - i had to remove the spoiler from the drivers' one as at 60mph it forced the blade so hard onto the screen that it made a loud juddering noise when it changed direction at 12 o'clock position. no noise now.
Quote from: migmog on 21 February 2016, 21:56:52
So they're poor then.
omega2018
no spoiler is poor, wipers fine.  actually spoiler works too well.  as spoiler is non standard (isn't it?) i removed spoiler - 2 screws.
