Fronteras replacement
Started by T.m.f, 17 February 2016, 22:47:32
2boxerdogs
Quote from: STEMO on 23 February 2016, 13:11:32
A 21 year old disco. Trouble free motoring
What could possibly go wrong 😀 😀 😀
;D
T.m.f
Well been busy buying stuff ready for off roading,got wading kit,safari snorkel,2" suspension lift spacers,extended flexi brake pipes,set off a/t tyres with wheels,glow plugs and rocker cover gasket.
Reconnected crankcase breather pipe to turbo inlet pipe,reconnected vac pipe to air filter box,replaced leak off pipes,cb radio fitted,dash cam fitted,more to do tho.
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
EMD
Will i have to widen the driveway gates for you to get through this time  ::) ;D
Omegatitis
Quote from: EMD on 03 March 2016, 16:22:29
It sounds like that won't be a problem..
..he'll just drive over them.
EMD
Quote from: aaronjb on 03 March 2016, 16:29:24
;D
Or winch them down  :D I bet it looks very different to when we picked it up ..
Omegatitis
T.m.f
It will look different over the next couple off weeks,just waiting on wheel bolts to fit the steel wheels to disco.
joshwyatt
I've got access to 'Microcat', which is the Land Rover parts catalogue. I can use VRN or VIN lookup. If there's any part numbers or diagrams you need, let me know! Anyone else with a Land Rover, I can do the same.
Microcat normally tells me date of manufacture and full trim specification, but for yours only tells me;
N4 ACB - I assume previous reg?
2.5 TDI EGR (GEM)
Wheel Base 100"
