Author Topic: Fuel gauge issue  (Read 1992 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Fuel gauge issue
« on: 21 February 2016, 11:13:08 »
Hi, guys...I recently replaced my cluster panel due to speedo/rpm not working with a cluster of ebay - the only one to match cluster serial number exactly.
Problem is fuel gauge and MID fuel left info show a bit different figures than I was used to.
On old cluster there was many miles between fuel light went off and MID started to show it's usual 50km left warning.
But on this one I get MID warning (MID is from my old panel) as soon after fuel light gets off.
I obviously don't want to try which reading is true....
Anyone knows why is this happening?
Regards Stan
Re: Fuel gauge issue
« Reply #1 on: 21 February 2016, 20:23:22 »
Did you swap the Mid over at the same time? Could be that the Mid is from a different engine/gearbox /wheel combo...
Other reason could be that your car is an estate, and the new cluster from a Saloon or vice versa... Saloons have a slightly smaller tank which does funny things to the gauge reading ;)
danzigfan
« Reply #2 on: 21 February 2016, 23:06:37 »
Thanks mate, MID wasn't replaced , I don't know which engine/model/transmission replacement cluster came from, I thought if the serial number was the same it's going to be ok....anyway, I reset MID today and now I'm waiting to see what happens next time when fuel level drops.
« Reply #3 on: 22 February 2016, 18:44:37 »
Post 1998 instruments have a code index to match it with engine, tyres etc
