Author Topic: repair top mount  (Read 2761 times)
jimjimanta
  • hellas
    • opel omega b , opel manta
repair top mount
« on: 22 February 2016, 09:59:20 »
i want a guide for the repair of top mount .
I searched the site , but i did not find.
trackcars
  • Merseyside
    • Omega 3.2 elite
Re: repair top mount
« Reply #1 on: 22 February 2016, 10:28:07 »
Do you mean the top front suspension mounts?
jimjimanta
  • hellas
« Reply #2 on: 23 February 2016, 13:45:05 »
sorry. yes front top mount .
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 23 February 2016, 13:52:50 »
In that case:
Remove the entire strut from the car.
Use robust, properly fitting spring compressors to safely compress the spring. This is the important part of the job, you can badly hurt yourself using poor equipment.
Undo the nut on the top of the strut.
Remove the top mount and bearing.
Replace them with new; I doubt you'll see any damage to the top mount until you compare it with a new one - they compress in use.
Tighten the top nut.
Refit the strut.
trackcars
  • Merseyside
    • Omega 3.2 elite
« Reply #4 on: 24 February 2016, 17:58:25 »
That's right I removed mine which looked ok but when compared they were definitely more compressed
