Author Topic: Heater matrix plastic couplings  (Read 6938 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Heater matrix plastic couplings
« Reply #15 on: 26 February 2016, 21:42:11 »
FWIW the heater pipes on a W124 Mercedes are a rubber pipe fitting over the metal pipe, admittedly with a "swollen" section... then held with a jubilee clip. Its not an unusual way to fit heater pipes IME.
It's the (alleged/theoretical) superiority of the spring versus Jubilee clip that is in question. My opinion is that the spring clip's advantages are purely production oriented which all disappear once  they are removed.
LC0112G
« Reply #16 on: 26 February 2016, 22:25:52 »
Well - a surprisingly easy fix which will hopefully hold till I've got less time. However, if you see a Mica grey OB Elite steaming at the side of the A303/M3 tomorrow morning then you'll know who it is.
One of these as opposed to a Jubilee would make it permanent :)
I normally hate those fekking things. Without the correct tool they can be a real git to fit and remove. However, in this instance they probably would have made things easier because getting to the screw on a jubilee clamp on the heater matrix pipework is a bit of a git - the access angles are all wrong.
