Author Topic: Project GNU  (Read 4956 times)
Re: Project GNU
« Reply #45 on: 18 July 2008, 23:25:03 »
All I did was run some coolant hose, and plug a connector in ;D
Good to see her in good health, though :y
What about the speedo / TC problem?/
hotel21
  • The Kingdom of Fife
Re: Project GNU
« Reply #46 on: 19 July 2008, 00:12:29 »
[split] [link=http://www.omegaowners.com/forum/YaBB.pl?num=1216422463][splithere][/link][splithere_end]
HNO3GOH
  • Somerset
  • Play time.
Re: Project GNU
« Reply #47 on: 19 July 2008, 09:05:04 »
Tell me more.
HolyCount
Re: Project GNU
« Reply #48 on: 19 July 2008, 10:49:39 »
Hmmm -- in the albeit short runs I have had in her, haven't noticed TC or Speedo probs.
Mind you, she hasn't been well enough to put TC to the test!
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Project GNU
« Reply #49 on: 19 July 2008, 11:06:56 »
If you know any one who needs a boat anchor then the old engine will make a good one :D
hmmm might be a bit overkill for my dinghy......  ::) ::)
HNO3GOH
  • Somerset
  • Play time.
Re: Project GNU
« Reply #50 on: 19 July 2008, 12:05:55 »
;D ;D ;D
Re: Project GNU
« Reply #51 on: 19 July 2008, 14:09:03 »
Lol, sorry, I had a falling out with the original person who worked on it due to his corner cutting and bloody mindedness through not listening and heeding the advice when working on this one.
So now the cat's coming out of the bag!!
don't tell me this was over the exhaust manifold gaskets  ::)
It was over the:
Fitting an unknown cheap nasty early engine
Non-gen cam cover seals
Not bothering with the manifold gaskets
Badly fitting the gearbox so as to destroy (as was found out later) the torque converter because the advice of fitting it to the box first was not heeded.
Then posting that there crap which was totally due to an incompitent worker who didn't practice what he preached!
The bodges I witnessed on some of the cars he bought was shocking and I could take no more!
Time and time again, as it saved a few quid.  Then due to using substandard gaskets complained Omegas were rubbish
Re: Project GNU
« Reply #52 on: 19 July 2008, 14:18:53 »
It was over the:
Hands up - when I first started tinkering with these cars I thought that all the comments for needing genuine gaskets were a bit OTT and tried pattern ones. Needless to say, I soon learned from the error of my ways after doing a few jobs twice  ;D
Having said that, when we did the HG on my current 2.0 all we had at the time was the pattern camcover gasket, so I used it with the intention of getting the GM one fitted ASAP afterwards.
At first I thought the pattern gasket was leaking a bit externally, but I'm not so sure, no oil loss and none in plug wells - and it's done 4k now incl the lakes trip and one to Wigan on a pattern part.
I must say, I suspect it's a time-bomb, waiting to blow ;D
Genuine GM all the way...
« Last Edit: 19 July 2008, 14:20:03 by JamesV6CDX »
HolyCount
Re: Project GNU
« Reply #53 on: 19 July 2008, 16:12:48 »
As MarksDTM said -- better to do the job properly, ONCE !
TBH, for the sake of a couple of quid, it's better to go for the real deal. And. once she is up and running properly, I don't want anything needing to be stripped down again for some time.
Pages: 1 2 3 [4]  All   Go Up
