Author Topic: 3.2 Battery  (Read 4763 times)
Ant - Petrol Blue Thirty Two
  • St. Ives, Cornwall
    • 2002 Elite Saloon 3.2
3.2 Battery
« on: 28 February 2016, 14:47:20 »
Hi to all.  Does anyone know the correct battery size (dimensions) and power for a 3.2 Elite?  Last replaced Dec 2008, at the time my Vauxhall dealer said that the original spec. battery was no longer available from GM and he went for the biggest size and amp (75?) that was available.
I think its shot now but want to buy the correct original spec battery - although not from GM.  Also what is a quality brand that will stand up to a 3.2?. Thanks.  Anthony
Re: 3.2 Battery
« Reply #1 on: 28 February 2016, 15:39:57 »
You may find Vauxhall as competitive for a genuine battery as a pattern supplier :y
I
JoeRadosavljevich
  • Serbia
    • '94 LPG'd Omega 2.0 16V
Re: 3.2 Battery
« Reply #2 on: 28 February 2016, 16:03:56 »
Having in mind that my car which is 4 cylinder, starts more than fine using bosch 74ah I suppose your car wouldn't mind having the same amount of amperes. I think larger capacity battery wouldn't be able to fit in.
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: 3.2 Battery
« Reply #3 on: 28 February 2016, 16:15:50 »
When I had my merc I when for the biggest battery that could fit in the boot 780cca
I would measure the tray then look for the biggest you can get. I recently bought a new batt for the v70 which I swapped over before getting rid of it as it a had a 4yr guarantee
e46 325i se - 1.8vvti avensis liftback
K_V6
  • Spain
    • Omega y22dth/Vectra let
Re: 3.2 Battery
« Reply #4 on: 28 February 2016, 16:47:52 »
Me too. Allways the biggest that I can fit it
From Spain. Sorry for my English
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: 3.2 Battery
« Reply #5 on: 28 February 2016, 17:30:39 »
2010 trade club book lists 93197903  85amp/hr (GM85-T7) for the 3.2 ,TC price then £69.13. I think they are all the same dimensions and fit on the tray. To my surprise when daughter-in-law's Rover Streetwise needed a new battery I managed to squeeze an Omega battery on to its battery tray, and it cranks the starter very well.
omega2018
    • MercCL500 Omega2.6ManElit
Re: 3.2 Battery
« Reply #6 on: 28 February 2016, 19:35:25 »
Type 110 Varta Silver Dynamic 12V 85Ah (F18) 585 200 080 fits, just.
Re: 3.2 Battery
« Reply #7 on: 28 February 2016, 21:11:37 »
Too tall...
Re: 3.2 Battery
« Reply #8 on: 28 February 2016, 21:34:12 »
IIRC, the trade club 85AH is for the 2.5TD and doesn't fit in a 3.2. Listing is wrong.
Standard fit is a 65 AH.
The AH capacity is no real indicator of the current it can deliver. Mine lasted 10 years and got replaced by a Yuasa 70AH / 650CCA battery which is fine.
    • 530D M Sport, 330i Coupe
Re: 3.2 Battery
« Reply #9 on: 28 February 2016, 22:12:23 »
The largest GM battery that will fit and allows you to keep the battery jacket is the 75Ah one.  :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: 3.2 Battery
« Reply #10 on: 29 February 2016, 15:53:25 »
Try battery megastore.
omega2018
Re: 3.2 Battery
« Reply #11 on: 29 February 2016, 17:00:21 »
Too tall...
nope, height is fine.  length is pushing it but fits. from tayna.co.uk was £62 ex vat inc del in 2013.
« Last Edit: 29 February 2016, 17:05:02 by migmog »
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: 3.2 Battery
« Reply #12 on: 29 February 2016, 17:04:40 »
It's just a bloody battery for a common car!
Go to your favourite/nearest/any supplier and tell them what you want it for.
Pick the one that's in the middle of the price range if you use the car frequently; spend a bit more if the car stands for longer periods.
Fit it in the carpark and get them to dispose of the old one.
JoeRadosavljevich
  • Serbia
Re: 3.2 Battery
« Reply #13 on: 01 March 2016, 11:10:20 »
Don't they buy back the old battery?
