Author Topic: Red antifreeze  (Read 8097 times)
less
  • Hemel Hempstead
    • 2.6 auto saloon
Red antifreeze
« on: 10 March 2016, 13:10:46 »
Hi all
I have a slow coolant leak somewhere which is a minor irritant. I have changed HBV and header tank cap but has made little difference. Never any visible signs of leakage so I will probably put up with it, and top up as necessary.
I can't always get to my nearest stealers when open as they tend to work same hours as me. Question is are all 'red' antifreezes compatible? I have seen red, blue and purple on eurocraparts for instance - would their red mix with mine without issue?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Red antifreeze
« Reply #1 on: 10 March 2016, 13:17:47 »
Any smell of antifreeze / water when the engines hot ?
I could be coming from the oil cooler plate and evaporating off ?
Any damp / wet patches in the footwells ?
less
  • Hemel Hempstead
    • 2.6 auto saloon
Re: Red antifreeze
« Reply #2 on: 10 March 2016, 13:26:28 »
Not noticed any coolant smell and no damp patches found.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Red antifreeze
« Reply #3 on: 10 March 2016, 13:27:01 »
No, all antifreezes are not compatible. I heard a tale of precipitation and clogging of an engine by mixing the old ethylene glycol antifreeze with the more modern organic acid stuff. Best to use the same again to top it up.
Check for drips and coloration at the bottom front of the engine. It it's water pump leaking that is where it will appear.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Red antifreeze
« Reply #4 on: 10 March 2016, 15:04:58 »
Any pink residue on the bottom of the radiator or the radiator drain plug ?
Re: Red antifreeze
« Reply #5 on: 10 March 2016, 16:53:08 »
Genuine can be bought readily on ebay for sensible money :y
If you can't see or smell it then it's most likely radiator related... Either one of the sensors or the drain plug ;) Have also changed a couple with cracked radiators...
Basically, start at the drain plug looking for residue, if any visible, follow the trail and fix/replace the leaky item...
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Red antifreeze
« Reply #6 on: 12 March 2016, 11:58:23 »
Could be leaking under the header tank
e46 325i se - 1.8vvti avensis liftback
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
Re: Red antifreeze
« Reply #7 on: 13 March 2016, 17:45:27 »
If your worried about mixing antifreezes, drain the system, flush through with clean water, drain and replace with OAT compatible antifreeze. As long as its OAT compatible, it won't matter what colour you put in to top-up... :y
D.I.L.L.I.G.A.F...
Re: Red antifreeze
« Reply #8 on: 13 March 2016, 23:30:15 »
Omega doesn't require OAT antifreeze - specified for more modern engines.  Just stick with the red GM antifreeze as specified.
It is NOT recommended to mix older antifreezes with OAT, particularly the old glycol based products as a gel will be produced!
omega2018
    • MercCL500 Omega2.6ManElit
Re: Red antifreeze
« Reply #9 on: 13 March 2016, 23:49:30 »
i though the GM red was OAT.  isn't it?
Re: Red antifreeze
« Reply #10 on: 13 March 2016, 23:58:28 »
No its not ;)
omega2018
Re: Red antifreeze
« Reply #11 on: 14 March 2016, 00:34:04 »
i think you might be wrong  ;)
omega2018
Re: Red antifreeze
« Reply #12 on: 14 March 2016, 00:56:35 »
from the astra owners manual 2012 (and others)
"Coolant and antifreeze
Use only organic acid type-long life
coolant (LLC) antifreeze approved for
the vehicle."
isn't that GM red or are they recommending some new GM colour, or a non GM coolant?
Re: Red antifreeze
« Reply #13 on: 14 March 2016, 01:19:35 »
the vehicle."
OAT antifreeze is NOT gm red.  OAT is for engines more modern than the Omega V6.  Yep its recommended for the more modern 2012 Astra, not for a 2003 or earlier Omega V6.
Try googling it re mixing oat with other antifreezes  - it will answer your query and confirm my posts ::)
Re: Red antifreeze
« Reply #14 on: 14 March 2016, 01:26:42 »
OAT is recommended by Jaguar for my XJ, and in the handbook it states OAT should not be mixed with non-OAT antifreezes.
GM, and other car manufacturers, don't make antifreezes, just supply "a n others" antifreeze to a specification with their own label applied.
OAT is coloured orange by the way, not red ;)
