Author Topic: wheel nuts  (Read 5736 times)
pauls
  • By the sea minehead
    • Bmw x3
wheel nuts
« on: 11 March 2016, 12:49:23 »
I have forgot what is the nm torgue for wheel nuts i think its 80nm
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: wheel nuts
« Reply #1 on: 11 March 2016, 12:57:08 »
Final right foot hard down, till it squeaks.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: wheel nuts
« Reply #2 on: 11 March 2016, 13:20:38 »
You're confusing units: 110NM,or (very) roughly 80Lb/ft
pauls
    • Bmw x3
Re: wheel nuts
« Reply #3 on: 11 March 2016, 13:49:16 »
Cheers nick.. :y
EMD
  • Noofhampton
    • 95t
Re: wheel nuts
« Reply #4 on: 11 March 2016, 14:06:31 »
Or the garage will do them up with a windy gun , they wont come off ever again  :(
Omegatitis
  • Chatham, Kent
Re: wheel nuts
« Reply #5 on: 11 March 2016, 17:20:01 »
one of these  http://www.sealey.co.uk/PLPageBuilder.asp?id=20&method=mViewProduct&productid=13939  will beat a garage's windy gun without breaking a sweat. Anyone still heaving away with Halford's wimpy efforts should invest £25(less if you look properly) in one.
  • Online Online
Re: wheel nuts
« Reply #6 on: 11 March 2016, 18:02:16 »
Not very convenient for use in the boot though  ::) ........ I have a cheapy extending wheel brace with a reverseable 17 19 socket on it .... 17 for the car & 19 for the caravan  :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: wheel nuts
« Reply #7 on: 11 March 2016, 18:47:55 »
I use one of those cross type wheel braces with the four different sized ends on.Can get some decent leverage with one of those!
Tony H
  • liverpool
  • Black Elites are luurvley
Re: wheel nuts
« Reply #8 on: 11 March 2016, 19:28:15 »
Two grunts and a fart! ;)
pauls
    • Bmw x3
Re: wheel nuts
« Reply #9 on: 11 March 2016, 19:31:35 »
I tried that but it wasnt a fart ;D ;D
  • Chatham, Kent
Re: wheel nuts
« Reply #10 on: 11 March 2016, 19:34:03 »
I use one of those cross type wheel braces with the four different sized ends on.Can get some decent leverage round off all the nuts and the end with one of those!
Corrected that for you.
BazaJT
Re: wheel nuts
« Reply #11 on: 11 March 2016, 21:31:10 »
Used it for more years than I care to remember and have never yet rounded a wheel nut off,nor ever failed to remove replace one with it either!You must be using it wrong if you have!
Re: wheel nuts
« Reply #12 on: 11 March 2016, 21:35:28 »
:o
That made I spill my drink... ;D ;D ;D
  • Chatham, Kent
Re: wheel nuts
« Reply #13 on: 11 March 2016, 22:02:00 »
Not me, I've never liked them and have tools better suited to the job. When you need a good heave on a 750mm breaker bar to undo a wheelnut a crossbrace isn't going to work. Many of them are poor quality and badly sized. Due to the design it's far too easy to angle it on the nut as you apply torque. This is even more likely if you add the locking nut.
I've been to far too many jobs where this type of brace has rounded both itself and the nut. Then you are into butchery and hope to get the nut off. Some are so bad that they ended up being recoveries.
Of course, the real problem here is incorrectly torqued wheelnuts, which is why I always use a torquewrench on mine.
  • Online Online
Re: wheel nuts
« Reply #14 on: 11 March 2016, 22:57:45 »
Honestly? Cross your heart ....... etc?  ::)
The last time I used a torque wrench for a wheel nut was to show my lad what the the correct torque felt like when you winged it with the wheel brace. I re-fitted a wheel just this afternoon on my daughter's car with an un-extended extendable brace.  :y
