Author Topic: wheel nuts  (Read 5755 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: wheel nuts
« Reply #15 on: 12 March 2016, 09:47:58 »
which is why I always use a torquewrench on mine.
Honestly? Cross your heart ....... etc? ::)
The last time I used a torque wrench for a wheel nut was to show my lad what the the correct torque felt like when you winged it with the wheel brace. I re-fitted a wheel just this afternoon on my daughter's car with an un-extended extendable brace.  :y
Yes. It hangs on the wall, and using it and putting it away means I know the whole job is finished.
Re: wheel nuts
« Reply #16 on: 12 March 2016, 09:54:40 »
Re: wheel nuts
« Reply #17 on: 12 March 2016, 10:30:26 »
Yeah, if I'm at home. If I'm not, they get loosened and re-torqued when I get home.
I know way 110Nm is (ish), but I like it to be right, given that I sometimes drive quite briskly, and as Nick W says, its part of the routine that you know you've finished.
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: wheel nuts
« Reply #18 on: 12 March 2016, 11:55:43 »
I use a short 12" breaker bar to loosen off (stays in the car) then a hellfrauds torque wrench to do up and it's not let me down yet and it's all because I can't work out the angle gauge  :-[
e46 325i se - 1.8vvti avensis liftback
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: wheel nuts
« Reply #19 on: 12 March 2016, 19:57:15 »
I have known overtightened and probably rusty wheel nuts defy hexagon sockets no matter how long the breaker bar, the socket eventually twisting off the nut. What shifts them is a big impact wrench, delivering a complete torque.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: wheel nuts
« Reply #20 on: 12 March 2016, 20:21:49 »
...... I have a cheapy extending wheel brace with a reverseable 17 19 socket on it .... 17 for the car & 19 for the caravan  :y
I did have one of these until recently and for the same reason, car and caravan wheel bolts.  :y
My lad used it to undo a hub nut on the truck, instead of using my long breaker bar.  ::) I now have an extending metal stick, as the square bit sheared off.  ;D
