Author Topic: Engine block swap  (Read 6728 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Engine block swap
« Reply #15 on: 13 March 2016, 21:55:36 »
Also, the later 3.0 heads do have tapped holes in which coil packs pick up into... although early 3.0 heads do not.
I fitted a 3.0 engine into a 2.6 I had a while back... went nicely too..
« Reply #16 on: 15 March 2016, 09:27:50 »
If you were thinking of fitting a 3.2 bottom end I would use 2.6 heads and port the inlets. I believe doing this brings the compression level up to the 3.0 levels...
This is what I have being toying with my own car. :y
Yes, the 3.2 has rather low compression, so I would be looking at what a 2.6 / 2.5 head would do to that, and what other work would be required in terms of porting and so on. The calculations are easy enough to do, so for someone experienced with tuning engines it'd be a no brainer.
On the other hand, transplanting a good 3.0 would be the simplest solution.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #17 on: 15 March 2016, 13:25:56 »
Already done that though Kev  :D
« Reply #18 on: 15 March 2016, 14:33:31 »
2.5 heads will work on a 3.2 bottom end and restore compression ratio to that of the 3.0
The heads will need porting to match the 3.2 inlet divider and ideally you would use the sodium filled valves from the 3.0/3.2 in the exhaust ports.
Valve sizes are the same
