£ 800 car tax
Started by raywilb, 12 March 2016, 18:41:59
Mine costs £500 pa to tax - I don't view that as a particular issue, if I did I would have bought an older car with all the inevitable increased maintenance costs ;)
Viral_Jim
Dbug, assuming this is the XJ in your profile, I'd consider £500 p.a. to be good value.
If nothing else for the amount of Her Majesty's Highway it takes up at any one time  ;)
Quote from: jimmy944 on 13 March 2016, 23:38:31
It is and not disagreeing  ;D ;D ;D :y  And as the good Doc Opti says, if I put suspension in sports mode and use the paddle gear change, a semi usually results, and the £10 tax per week pales into insignificance compared to petrol costs  :y ;D ;D
Broomies Mate
Why can't they charge the VED on the ACTUAL emission from YOUR car?  It is tested at the MOT station every year, including recording the mileage travelled since last MOT (if you want).
Admittedly, my mathematically retarded brain wouldn't be best suited to drawing-up the calculations required, but I'm sure someone with a modicum of number-crunching could do it.
I don't see why my highly maintained car which currently does around 6k a year and from the Emissions print-out runs on clouds should be charged at the same rate as an identical car which travels 30k a year and gets an oil change when the 'abuser' feels like it.
I suppose it would cause problems when buying/selling a vehicle?
Incorporating VED into taxation on fuel would be another option, but that doesn't address the good car/bad car argument.
Quote from: Broomies Mate on 13 March 2016, 23:57:51
Why can't they charge the VED on the ACTUAL emission from YOUR car?  It is tested at the MOT station every year...
MOT emissions and VED emissions are two completely different things.
GastronomicKleptomaniac
Quote from: TD on 13 March 2016, 18:10:42
Quote from: Doctor Opti on 13 March 2016, 18:01:55
Quote from: STEMO on 12 March 2016, 20:59:39
I have told my wife that her car must last at least 20 years, £0 tax will save a lot of money over that period. I may buy a zero tax car before 2017 as well.
£500 each year equates to £10 a week.
That's 3 pints of beer  ;) :)
Or 4 if you're a Northerner...
Quote from: GastronomicKleptomaniac on 14 March 2016, 12:16:35
.. where a quarter of each pint is foam, so it amounts to the same thing. ;)
Quote from: Kevin Wood on 14 March 2016, 12:05:29
Yes , the MOT emissions is just a basic check that the engine and setup aren't catastrophically bad at idle.
baggers
Quote from: raywilb on 12 March 2016, 18:41:59
article in daily mirror tories contemplating £800 road tax on diesel motors
And so they should, they kick enough shit out of the back.  Get behind a 4 year old+ diesel and your lucky if your not left in a cloud of crap.
Quote from: baggers on 14 March 2016, 23:50:53
Yup, my shitbox sootchucker works better than dipping rear view mirror at night...
True, and just think how you could fiddle the results if you used snake oil instead of petrol, or one of the many excellent suggestions in tother thread ;D
Government would be broke, sorry more broke, in no time at all ;D
Quote from: Harris K Telemacher on 15 March 2016, 09:49:38
Just imagine how much easier it would be if we controlled fuelling via electronically controlled injectors. Then we could get a nerd to write some clever software to fiddle the test without any expensive additions.
What could possibly go wrong?
Quote from: Nick W on 15 March 2016, 11:19:38
Well... now you mention it... ;D
baggers
Quote from: TheBoy on 15 March 2016, 09:44:33
;D   ;D
Rods2
No emissions means VW's will soon be zero VED rated then. ::) ::) ::)
