Author Topic: Additives  (Read 8207 times)
Discoja
  • Peterborough
    • Omega 2.2 dti cdx
Additives
« on: 15 March 2016, 16:16:27 »
Hi all
My car runs fine and HD very regular services, it's a 2.2 dti. A few friends use a couple of different brands of fuel additives in there engines. Has anybody got any opinions on this, are they worth the mone. Will they do as they say on the bottle??? Increase response, fuel consumption and so on.
Thanks in advance
Of all the things I've ever lost, my mind I miss the most.
Re: Additives
« Reply #1 on: 15 March 2016, 17:09:28 »
Wynns products do exactly what they say on the tin :y
Discoja
  • Peterborough
    • Omega 2.2 dti cdx
Re: Additives
« Reply #2 on: 15 March 2016, 17:25:26 »
The two that have been mentioned are:
Cataclean
Forte
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Additives
« Reply #3 on: 15 March 2016, 17:31:45 »
I've used. Cataclean, Wynns, Forte.. Can't say which works the best but I have notice Cataclean seems to liven the engine up a tad and a little more mpg, Plus it's a good thing to use before an MOT. I usually get it from eBay or Amazon or Euro Car Parts depending who's the cheapest usually around £13.
Vicar
  • staffs border
    • 2.0 CD
Re: Additives
« Reply #4 on: 15 March 2016, 17:38:46 »
I have had good success with the Forte fuel additives. :y
omega2018
    • MercCL500 Omega2.6ManElit
Re: Additives
« Reply #5 on: 16 March 2016, 01:30:12 »
Definitely snakeoil...
Re: Additives
« Reply #6 on: 16 March 2016, 05:10:13 »
Based on what? Heresay? A vivid imagination? Or simply an overwhelming urge to say summat contrary because I said it?
Their lifter treatment does exactly what it says on the tin, their fuel system cleaner helps purge the effects of shit fuel...
I'm sure Dbug will be along shortly to agree with you amd would go as far as to suggest that the only reason he hasn't posted yet is because I hadn't.  :-X
Re: Additives
« Reply #7 on: 16 March 2016, 08:34:59 »
Wynns lifter treatment I've seen work (though not always - it won't repair a fooked lifter).  Forte fuel system cleaner works in petrol cars. Redex for diesel can help reduce smog if you use supermarket diesel.
Holts Speedflush is shite for cleaning coolant systems. Their engine oil flush is equally shite.
These are based on my own personal experience.
Viral_Jim
  • Telford
    • Too many, mostly broken
Re: Additives
« Reply #8 on: 16 March 2016, 09:12:19 »
I used redex to revive the injectors on my Mk3 mondeo tddi. Not in the recommended concentration mind, 1 bottle of redex to 4.5L diesel. The clouds of cr@p made the whole cul de sac look like the set of Starlight Express  ;D
Never used a petrol additive, never seen a need, but if I did, I'd give it a whirl.
EMD
  • Noofhampton
    • 95t
Re: Additives
« Reply #9 on: 16 March 2016, 14:49:50 »
Use to add redex neat into the carb while the car was running years ago , was most pleasing seeing a cloud of smoke and crap fly out the pipes  :D Just ordered some WYNNS PETROL INJECTOR CLEANER ADDITIVE and will add some special high octane  :P
Omegatitis
Re: Additives
« Reply #10 on: 16 March 2016, 15:08:55 »
I'm sure Dbug will be along shortly to agree with you amd would go as far as to suggest that the only reason he hasn't posted yet is because I hadn't:-X
Are those sort of comments really necessary?  Grow up and act your age!   >:(
As it happens I endorse your comments on Wynns products having used them mysef over many years.  They certainly aren't "snakeoil".
« Last Edit: 16 March 2016, 15:22:15 by dbug »
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Additives
« Reply #11 on: 16 March 2016, 16:08:25 »
It keeps the dash lights out  :y
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Additives
« Reply #12 on: 16 March 2016, 18:44:10 »
Fwiw I just used some Wurth engine flush on MrsGK' s Lupo and it worked a treat - sorted the tapping from the top end.  :y
Discoja
  • Peterborough
    • Omega 2.2 dti cdx
Re: Additives
« Reply #13 on: 17 March 2016, 09:00:07 »
Interesting comments so far,  so which is highly recommended for diesel cars then?
Viral_Jim
  • Telford
Re: Additives
« Reply #14 on: 17 March 2016, 18:00:47 »
Redex worked for me. Never tried other brands.
