Author Topic: auxiliary water pump removal  (Read 4543 times)
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
« on: 18 March 2016, 12:19:45 »
Just a quick and simple question: does an auxiliary electric water pump (the one below expansion tank) have any effect on engine cooling?
But I need a 100% definite answer.
From what I know, it only serves to keep the heating on when engine turned of (by circulating water trough cabin heater).
I am planing to remove it – I really never need the cabin heating feature, and the hoses towards the pump are cut in several places (as it was LPG fitted), but want to be 100% sure it will not affect engine cooling capacity in any way.
Also, I would remove two hoses (one from colant bridge to pump, and other from pump to heater matrix) -> is there an OEM hose that goes from coolant bridge directly to heater core (bulkhead)?
Following the link below -> I will remove items 4 and 5, and replace them with item no.3
http://www.partsbase.org/opel/omega-b-1994-2003-6--7-13-1-hoses-and-pipes-contd-x25xe-l80-y26se-ly9-x30xe-l81-y32se-la3-engines/
Re: auxiliary water pump removal
« Reply #1 on: 18 March 2016, 13:02:45 »
No. It's there purely to make use of residual heat in the engine for heating the cabin when the engine's stopped.
I removed mine when I LPG converted it with no ill effects. You can buy the hose assembly from a car without the pump to do a neater job of removal. If you look in the LPG guides here, you might find the part number.
baggers
  • Heywood, Mcr
    • Omega 3.0 & 2.2
    • Carlton, Senator, Omega Spares.
« Reply #2 on: 18 March 2016, 15:11:54 »
WTF that link just redirected to a shagging site.
« Reply #3 on: 18 March 2016, 15:14:46 »
Worked OK for me.  :-\
EMD
  • Noofhampton
    • 95t
« Reply #4 on: 18 March 2016, 15:36:00 »
  :o
Omegatitis
    • 530D M Sport, 330i Coupe
« Reply #5 on: 18 March 2016, 17:21:34 »
Non-aux pump coolant pipe 9129564
baggers
  • Heywood, Mcr
    • Omega 3.0 & 2.2
« Reply #6 on: 18 March 2016, 19:30:03 »
You missed the eye full I had  ;D
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #7 on: 18 March 2016, 19:44:18 »
Do you have air-con (and therefore a heater-bypass valve)?  The diagram in your link is for models without air-con and the plumbing is subtly different.
The hose you want is the one used for models with cruise control - they didn't have the aux pump.
What model, year and engine do you have?  (if you add this to your profile, it'll save you being asked this every time)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 18 March 2016, 21:03:56 »
You must have gone to your history by mistake ;D
Hoof'land storeman.
sjc
  • Alloa, Scotland
« Reply #9 on: 18 March 2016, 21:04:23 »
Assuming V6, the hose you want to bypass the aux pump is..
With air-con...
 9129566  18 18 134 HOSE, HEATER, WATER INLET, HEATER VALVE, RHD (FOR AUTO CRUISE CONTROL) X25XE, X30XE  (C) X1104259-
Without air-con (as already mentioned by VXL V6)...
 9129564  18 18 122 HOSE, HEATER, WATER INLET, RHD (FOR AUTO CRUISE CONTROL) (IDENT GQ) X25XE, X30XE  (C) X1080658-    1
biggriffin
« Reply #10 on: 18 March 2016, 21:05:31 »
That link is corrupted.........o Er missus :o
Hoof'land storeman.
  • Auckland
    • Mazda MPV
« Reply #11 on: 18 March 2016, 21:41:13 »
With air-con...
It is 25 years since I went on holiday in Croatia but I am pretty certain that Bojan will have his steering wheel on the left (LHD) not RHD
sjc
  • Alloa, Scotland
« Reply #12 on: 18 March 2016, 22:18:20 »
With air-con...
Same parts for LHD/RHD..
With air-con...
 9129566 18 18 134 HOSE, HEATER, WATER INLET, HEATER VALVE, LHD       1
    Note: EXC.FINLAND,NORWAY,SWEDEN
 9129566  18 18 134 HOSE, HEATER, WATER INLET, HEATER VALVE, RHD (FOR AUTO CRUISE CONTROL) X25XE, X30XE  (C) X1104259-    1
Without air-con...
 (90466592)  (18 18 400) HOSE, HEATER, WATER INLET, LHD (NLS.- USE 9129564 18 18 122) X25XE, X30XE  (C) R1000001-  S1100328  1
 (90466592)  (18 18 400) HOSE, HEATER, WATER INLET, RHD (FOR AUTO CRUISE CONTROL) (NLS.- USE 9129564 18 18 122) X25XE, X30XE  (C)   -X1080657  1
  9129564  18 18 122 HOSE, HEATER, WATER INLET, LHD (EXC.FINLAND, NORWAY, SWEDEN) X25XE, X30XE  (C) X1080658-    1
    Note: EXC.AIR CONDITIONING
« Reply #13 on: 18 March 2016, 22:22:05 »
Feeling left out now. :(
baggers
  • Heywood, Mcr
    • Omega 3.0 & 2.2
« Reply #14 on: 18 March 2016, 23:37:01 »
