Author Topic: Thermostat and Water Pump on a 2.5 Diesel  (Read 6563 times)
Kate
  • Cornwall
    • Drives people mad
« on: 19 March 2016, 17:12:03 »
Hi all. :y
Sorry to be a nuisance with all my questions. I know I'm a pest. ;D
I'm going to have a go at changing the thermostat and water pump on my overheating diesel. I've read the guide for the water pump but I can't find a guide for the thermostat. Is there a Haynes manual that would cover this job? I've looked at lots of manuals for sale online but none seem to cover the 2.5 diesel engine.
Thanks for all the help! :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Thermostat and Water Pump on a 2.5 Diesel
« Reply #1 on: 19 March 2016, 17:16:23 »
Not for the Omega, if you need a Manual best bet is for an older BMW 325, 525 etc with the same lump 2.5TD.
Not sure if this will help you -
http://images.omegaowners.com/documents/25TD/M51D25_Engine.pdf
« Last Edit: 19 March 2016, 17:31:24 by Zirk »
« Reply #2 on: 19 March 2016, 17:51:24 »
I thought a mobile mechanic diagnosed a HG failure?  :-\
Kate
  • Cornwall
    • Drives people mad
« Reply #3 on: 19 March 2016, 18:06:31 »
He did but I wanted to be certain, one way or the other.
Kate
  • Cornwall
    • Drives people mad
« Reply #4 on: 19 March 2016, 18:08:47 »
Thanks very much, that's very helpful. :y
« Reply #5 on: 19 March 2016, 23:02:07 »
A compression test would be a better approach.  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6 on: 23 March 2016, 20:39:26 »
Spotted this genuine Vauxhall 2.5TD water pump going pretty cheap.
https://www.ebay.co.uk/ulk/itm/152023490089
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 23 March 2016, 20:53:10 »
Did you notice the plastic impeller? Metal ones are less problematic
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #8 on: 23 March 2016, 21:08:33 »
I did but though't I'd share either way. I am aware metal impellers are the preferred choice given the option. Anyway...
Kate
  • Cornwall
    • Drives people mad
« Reply #10 on: 24 March 2016, 18:06:32 »
Stat dead easy when doing pump - basically disconnect hose, unbolt housing, replace stat.
Hardest bit of whole pump/stat job is removing the viscous fan, which can be a bugger.
  • Chatham, Kent
« Reply #11 on: 24 March 2016, 19:08:23 »
You loosen it as soon as you have room to get a fan spanner on it, by giving that a bash with a proper hammer. As long as you've checked which hand the thread is , it isn't a difficult job.
« Reply #12 on: 24 March 2016, 19:16:58 »
Oh, believe me, if only ze germans had made it that easy. idiotting it rarely works, which I guess is why BMW/LR/GM specify a pulley lock to counterhold before said idiotting.
Like many (stupid, poxy) viscous fans, its LH thread on the TD lump, for reference.
Kate
  • Cornwall
    • Drives people mad
« Reply #13 on: 24 March 2016, 19:24:40 »
The fan is missing so I didn't need to remove it.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #14 on: 24 March 2016, 20:08:35 »
I had to remove the vicious (deliberate typo!) fan many times due to overheating problems, so when you get a fan to put on, Kate, it WILL be a left-hand thread, because it helps it to tighten as the engine rotates - otherwise it could spin off in service.
Should you need to remove it at a later date, a tip from a garage man in Cornwall - take a beefy screwdriver with a pound-through handle, hold the blade firmly against a corner of the fan's retaining nut at its RH edge, and give the handle end of the screwdriver a firm and sharp tap with a grown-up hammer!
Ron.
