Author Topic: Thermostat and Water Pump on a 2.5 Diesel  (Read 6550 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Thermostat and Water Pump on a 2.5 Diesel
« Reply #15 on: 24 March 2016, 20:11:18 »
Stat dead easy when doing pump - basically disconnect hose, unbolt housing, replace stat.
Hardest bit of whole pump/stat job is removing the viscous fan, which can be a bugger.
You loosen it as soon as you have room to get a fan spanner on it, by giving that a bash with a proper hammer. As long as you've checked which hand the thread is , it isn't a difficult job.
Oh, believe me, if only ze germans had made it that easy. idiotting it rarely works, which I guess is why BMW/LR/GM specify a pulley lock to counterhold before said idiotting.
Like many (stupid, poxy) viscous fans, its LH thread on the TD lump, for reference.
I realise you've probably never heard this before, but you're not hitting it hard enough ;D  It's like breaking tapers loose, a hard, sharp impact is required.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #16 on: 24 March 2016, 22:35:30 »
In the first few years I owned my TD, I left the fan in place, but when it needed to come off, I never had a problem, just a sharp tap on the large open ended adjustable while holding the fan.
Kate, the stat is dead easy as described above, with the added bonus of no 'B' bolt! I replaced my pump with a metal impeller about 10 years ago, and have had no problems since. :y
Kate
  • Cornwall
    • Drives people mad
« Reply #17 on: 24 March 2016, 22:57:54 »
I've done the stat already, just waiting for the water pump off ebay then I'll fit that.
Should I try and get a fan or will it be okay without one?
relluf
« Reply #18 on: 24 March 2016, 23:09:02 »
Should I try and get a fan or will it be okay without one quote]
Kate leave it off !!
If you really want one its in my shed I will send it to you but you really don't need it.
Kate
  • Cornwall
    • Drives people mad
« Reply #19 on: 24 March 2016, 23:17:42 »
Thanks Andy, I'll leave it off then. :y
« Reply #20 on: 25 March 2016, 12:00:24 »
In the UK, the viscous isn't needed. Actually, it does more good to leave it off.
Kate
  • Cornwall
    • Drives people mad
« Reply #21 on: 25 March 2016, 20:30:07 »
Great, one less job to do then. :y
