Pages: 1 2 [3]  All   Go Down
Author Topic: Front Discs, any recommendations....  (Read 11378 times)
jb
  • bucks
    • 3.2 Elite
Re: Front Discs, any recommendations....
« Reply #30 on: 25 March 2016, 07:32:35 »
Key to free moving pads is  to
1. Clean the pad carriers with emery paper and then test fit the pads(sanding down the pad locator tabs of any excess paint if required) then lube up all contact points (carrier and pads)with ceratech brake lube ensuring that no excess comes in contact with disc.
2. Check that slider pins move freely and dismantle,clean and lube if req. never had to replace the rubber boots.
3. Check piston moving freely and rubber boot in place and undamaged. Use g lamp or piston retraction tool and often good to push back and pump out a couple of times.
Binding often due to build up of crud and rust in the area of carrier and pad tabs.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #31 on: 25 March 2016, 07:55:35 »
Completely agree with all of the post from JB :y
Of all the brake jobs I've done at work I've seen siezed slide pins maybe 3-4 times. Pads seized in to place is super common.
As you'll be fitting discs you'll have the carrier off and therefore real easy to get a wire brush in to all the nooks and crannies
RIP Paul Lovejoy
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #32 on: 25 March 2016, 08:01:27 »
Are the slider pins easy to remove ?
If I was to take take them off then I may as well put a new set on was my thinking as they will be 16 years old  :y
Assume not that extortionate from the Stealer for a set ?
Webby the Bear
  • Northampton
« Reply #33 on: 25 March 2016, 08:06:53 »
The slide pins will pull out. If they're seized get a pair of mole grips on the end and twist them out.
When you put your new ones in (or your freshly lubed old ones) push the slide pin in and then pinch the rubber boot with your fingers to expel any trapped air.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #34 on: 25 March 2016, 08:07:54 »
Ps as for replacement I wouldn't bother. They usually come up really nice with a good wire wheeling
RIP Paul Lovejoy
DrAndyB
« Reply #35 on: 25 March 2016, 08:20:52 »
 :y :y thanks.
I have taken caliper off at last disc change ( several years ago now) so I am sure it will all come back  :y
Sounds easier than the rubbish sliders which used to sieze on my old Carlton Diplomat  ;D
Webby the Bear
  • Northampton
« Reply #36 on: 25 March 2016, 10:07:06 »
 :y :y thanks.
Just make sure you leave yourself a note on the steering wheel to pump the pedal if it's been a while. Guarantee you'll remember it as soon as you've reversed in to the house over the street  ;D
And top off the fluid  :y
RIP Paul Lovejoy
DrAndyB
« Reply #37 on: 26 March 2016, 19:57:56 »
Update.
Disks and and pads now changed  :y
The hot wheel was I believe a stiff piston on the calliper as it was hard to push back (sliders were all free, but I took out and greased and appeared like new  :y )
I have cleaned around the piston, and pushed seal back and cleaned outer of piston and it looked all clean, shiney and no corrosion. Worked piston back and forth about 20 times and it feels the same as the other side.  Not sure if this is prolonging the issue and that I need to replace  calliper ????  Can you get a piston service kit ?  Guess best to keep an eye on things and at slightest "warm wheel" replace calliper ?  Assume a pair of GM ones are not cheap  :'(
Also noticed that the new GM pads came pre chamfered on the ends  :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #38 on: 28 March 2016, 01:04:03 »
seals/service kits are available, but you've most likely 'turned the clock back' on your calipers by quite a few years by that day's work.  :)
Pages: 1 2 [3]  All   Go Up
