Author Topic: wet footwells  (Read 2170 times)
gbh
  • forest of dean
    • omega cdx 2.6
wet footwells
« on: 21 March 2016, 20:56:38 »
Hi all,Have a wet problem and having read the posts i checked the water outlet in the engine bay,no problem but the sunroof is a problem with water running on the inside and out.I pushed some cable down and then tried water still same problem.So is it a pipe or a U shaped channel which seems to go forward towards engine bay?I was pouring a lot of water but if it was a pipe it wouldn't matter,anyone with experience of this?Thanks Glenn
Re: wet footwells
« Reply #1 on: 22 March 2016, 08:26:29 »
There's a drain tube is in each corner. The fronts go down each A post into the sills and rears drain through each side of the boot (saloon) behind the spare & where the first aid kit lives.
Dodge
  • Wrexham
    • 2.2 CD auto lpg/petrol
Re: wet footwells
« Reply #2 on: 18 April 2016, 13:22:32 »
Is it the front passenger footwell that gets wet?
gbh
  • forest of dean
    • omega cdx 2.6
Re: wet footwells
« Reply #3 on: 18 April 2016, 20:06:56 »
Certainly more wet on that side but seems to have dried up a bit since flushing,which certainly made it wetter.Hopefully its now ok but will keep a close eye on it...
