DBW
Started by BazaJT, 26 March 2016, 20:04:56
Quote from: zirk on 28 March 2016, 20:13:43
Quote from: YZ250 on 28 March 2016, 19:22:15
No rev limiter back in those days Kevin, not sure it had even been invented.  :-\ Car in question was my Capri 3.0S which I owned for just over six years, so the event was quite some time back.  :y
They were quiet nippy,  :y a friend of mine had a 3.1 RS years ago.  :)
The cams were a fairly effective rev limiter, if memory serves. ;)
Quote from: Kevin Wood on 28 March 2016, 23:30:55.....
Would that not be cam ..... in the singular?  :-\
Quote from: Andy B on 29 March 2016, 00:17:42
The single camshaft on those still has 12 cams on it ;)
It's actually the inlet manifold that's restrictive. Mill the separator out of the plenum and rather than running out puff at 5k rpm it will go over 6 with no other mods. Did this on several engines. Although you do exacerbate some of the other Essex problems - the rockers constantly need resetting, a heavy-duty oilpump drive becomes essential rather than just a good idea and the timing gear is even more likely to fail. It's designed for use like American V8s, low-end torque rather than revs
Quote from: Harris K Telemacher on 29 March 2016, 05:48:39.....
Good point .... well made  :y :y
