Author Topic: Coolant change interval  (Read 2682 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 26 March 2016, 21:22:35 »
Haynes change coolant every two years. Does that apply to GM Dex-Cool 50/50 or is the interval longer? Reading other threads poor or old coolant risks oil cooler and other failures.
Re: Coolant change interval
« Reply #1 on: 26 March 2016, 21:56:05 »
I changed the 5 year red coolant every 3 years.
4.5 litres for a 50/50 mix in a proper Omega.......not sure about the lesser 4 cylinder cars. :)
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 26 March 2016, 22:04:17 »
Thanks. Last time I bought some trade club Dex-Cool they forced 20 litres on me at £19.95, which seemed cheap enough to me to change frequently if worthwhile..
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #3 on: 27 March 2016, 10:46:50 »
Best recommendation seems to be that no matter which coolant you buy be it 2yr,5yr,10yr or whatever,to roughly halve those values for changing.
« Reply #4 on: 27 March 2016, 12:06:09 »
Yup, half the stated life, due to the way it degrades.
So annually for the old style blue stuff, and 2.5yrs for the long life stuff :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 27 March 2016, 17:29:28 »
Why worry about it? The cars are old enough, and fussy enough that you're bound to have to work on the cooling system before the coolant needs replacing.
« Reply #6 on: 27 March 2016, 18:43:01 »
Oi! They ain't clapped out Capris ;D.
Or have I got the only 2 that are reasonably continent ;D
  • Chatham, Kent
« Reply #7 on: 27 March 2016, 19:49:11 »
Oi! They ain't clapped out Capris ;D .
Exactly my point; the worst cooling job on a Capri is that it might need a heater matrix once(if!) it passes about 25 years old. £30 part which requires removing the dash. That's about a 2hour job. Did one last week. Water pump - 15minutes, radiator - 5minutes. Cast iron engines, so anti-freeze(type or even strength) isn't critical.
« Reply #8 on: 27 March 2016, 19:53:28 »
Best heater matrix I've done was on my Manta ....... 20 mins top including supping your brew  :y
  • Chatham, Kent
« Reply #9 on: 27 March 2016, 19:55:54 »
Mk3/4/5 Cortina - Open the bonnet, undo the 2 hose clamps, 3 self-tapping screws and it falls out. Put it all back together, and if you filled the kettle for your tea, it will have just boiled!
