Author Topic: Fitting a towbar.  (Read 6821 times)
johnnydog
  • Online Online
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Fitting a towbar.
« Reply #15 on: 29 March 2016, 22:05:36 »
Fitting a removable towbar is the obvious solution ::)
I think a removeable towball would be easier..... ;D
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #16 on: 29 March 2016, 22:10:46 »
Mine also has no problems with the towbar and reverse sensors either... It does go a bit nuts when the caravan is hitched up and I start to reverse though LOL
D.I.L.L.I.G.A.F...
« Reply #17 on: 30 March 2016, 09:11:36 »
IIRC, there is some provision in the factory towbar wiring for the reversing sensors to be disabled in the same way that the rear fog lights are when towing.
« Reply #18 on: 30 March 2016, 09:24:25 »
The factory loom I had fitted used a simple switch in the side of the 13 pin socket to turn the rear fogs off when a trailer was plugged in
« Reply #19 on: 30 March 2016, 09:28:44 »
Yes, and I think there's some connection between that switch and the reversing sensors. Must have another look at the diagram.
Of course, the switch tends to be a nasty bit of bent brass in the towing socket that eventually gets damp and corrodes, then you fail the MOT due to inop fog lights. ;)
« Reply #20 on: 30 March 2016, 09:45:52 »
It's beeen a while  ::) ...... there were two blue/black wires from the car down to the socket to a normally closed switch which maintained the car's fogs when no trailer was plugged in. Plugging a trailer in opened the switch, turned the car's fogs off and powered the trailer's fog(s)
« Reply #21 on: 30 March 2016, 10:40:31 »
There is no "auto off" sensor that I know of .. when reversing with the van on you live with the noise ..
There is with the original genuine loom.
