Author Topic: Easiest way to get small cable from dash to engine bay  (Read 6955 times)
« on: 29 March 2016, 14:34:23 »
Small cable needs to go from behind dash into engine bay.
Where is best place to go through?
Re: Easiest way to get small cable from dash to engine bay
« Reply #1 on: 29 March 2016, 14:38:14 »
Depends if it's the one with the cable throttle or not.
If DBW, there's a handy blanking grommet where the cable used to be.
« Reply #2 on: 29 March 2016, 14:47:54 »
Its the superior engine, so some pratt has put a throttle cable through there :(
« Reply #3 on: 29 March 2016, 15:37:07 »
Poke it through the big grommets in the pollen filter area, I guess.
Although.. is there a brown crusty bit on the bulkhead you can poke a hole through? :-X
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 29 March 2016, 16:23:41 »
That's what I used. :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 29 March 2016, 16:38:30 »
Open window, open bonnet, feed cable, job done.  :)
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #6 on: 29 March 2016, 16:39:29 »
There's probably more brown crusty bits in the bulkhead area than you might think!!! You'll be spoilt for choice with an Omega  :y
Omega 2.5 V6 Facelift Estate.
« Reply #7 on: 29 March 2016, 17:05:01 »
Ideally wanted a shorter run.  Suppose I'll have to have a poke around.
And, being the superior MFL model, the only rust is on the bodyshell ;D
« Reply #8 on: 29 March 2016, 17:25:31 »
Think you'll find the bulkhead is a critical bodyshell component ::)
Just off to the right of the throttle cable is another loom run ;)
« Reply #9 on: 29 March 2016, 18:25:41 »
Rain stopped play (not that play started ;D)
« Reply #10 on: 29 March 2016, 21:12:39 »
Either as HKT says or, iIIRC, there is enough space in the throttle cable grommet to squeeze another cable through :-\
Failing that... Follow where we poked the LPG wires through ::)
« Reply #11 on: 29 March 2016, 21:36:45 »
Pop the scuttle off and follow the brakefluid/coolant sensor
loom back towards the dash :y
« Reply #12 on: 29 March 2016, 21:44:27 »
I found a small blanking grommet underneath the large loom that passes through the bulkhead in the pollen filter housing on my MFL
« Reply #13 on: 30 March 2016, 01:33:13 »
If you're going all the way over there, then you might as well pop it through with the rest of the loom ::)
« Reply #14 on: 30 March 2016, 08:50:33 »
Just availing Jamie to all the options .....  :P  ;)
