Author Topic: Self levelling suspension pump  (Read 3372 times)
« on: 04 April 2016, 15:17:25 »
Can anyone advise if the self-levelling suspension pump from a 2000 3.0 Elite is the same as a FL 2001 3.2 Elite ??
James might have a 3.0 one available to me if it's the same
Ta in advance
Nige
Re: Self levelling suspension pump
« Reply #1 on: 04 April 2016, 17:01:32 »
Be very surprised if they weren't all identical :y
amba
  • Medway towns
    • German V6
« Reply #2 on: 04 April 2016, 17:18:44 »
All identical.
Took the original pump off my 1998 Elite and fitted it to my 2003 Elite,until rear shocks gave up so resorted to std non SL setup.
Only thing I did find was the black rubber vent pipe had albut perished so you might need a new bit of rubber tube but fuel pipe worked fine as its only a vent to atmosphere.
« Reply #3 on: 04 April 2016, 17:34:41 »
Magic thanks ... just need to hear from James now .... :)
« Reply #4 on: 04 April 2016, 18:19:19 »
All post 1998 ones are the same BUT may be calibrated differently.
Pre 98 ones are different.
« Reply #5 on: 04 April 2016, 21:58:19 »
Thanks for the info ... given those facts .. in your opinion would I be better trying to get a FL / 3.2/ 2001 pump rather than the 3.0 one James might have ??
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #6 on: 04 April 2016, 22:01:20 »
I took a compressor off a late PFL estate many years ago, and subsequently fitted it to a 2001 3.2 Elite saloon, and it work perfectly. No difference in the connections or mounting points.
« Reply #7 on: 05 April 2016, 18:17:06 »
Your call. As long as its post 1998 (ie, from a MFL or FL).
« Reply #8 on: 05 April 2016, 18:45:47 »
Ta .. If the one from James is still available I'll probably go with that then .. 2000 3.0 so must be MFL  :)
« Reply #9 on: 06 April 2016, 18:12:34 »
I think its actually a FL, but matters not really ;)
