Author Topic: Range of Keyfob  (Read 8948 times)
mantamania
  • Chatham, Kent
    • 2.6 Elite
Range of Keyfob
« on: 07 April 2016, 10:59:43 »
Hi all,
Is there a way of extending the range of the remote keyfob for the central locking. I have had a couple of face lift omegas and have found that the range is not great even with new batteries.
2boxerdogs
Re: Range of Keyfob
« Reply #1 on: 07 April 2016, 11:11:15 »
Hold the key next to your head, sounds silly I know but increases the range by quite an amount.
Re: Range of Keyfob
« Reply #2 on: 07 April 2016, 11:17:06 »
As long as it opens before you get to the car, how far away do you want/need to be able to open it?  ::) My Merc will open from that far away, that it's locked itself again before I can walk to it!  ::) ::) (But I have to stand next to it for the infra red total closure to work  ??? ???)
Re: Range of Keyfob
« Reply #3 on: 07 April 2016, 11:40:11 »
That's probably so that you can be sure that nothing is in the way of the windows etc as they close... otherwise a window could stop and the car would remain unsecured ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Range of Keyfob
« Reply #4 on: 07 April 2016, 12:23:53 »
Omega's never have been good on range, strangely Ive always found the Estates to worse than the saloons.  :-\
You could in theory extend / relocate the receiver aerial pickup on the vehicle side if your up to it, but a lot of fuffing around for a tad more extra range.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Range of Keyfob
« Reply #5 on: 07 April 2016, 13:36:27 »
How much do you need? My estate opens from the other side of the street, or several parking spaces, which is plenty.
Have you checked the condition of your fob? A loose battery holder could be the cause
omega2018
    • MercCL500 Omega2.6ManElit
Re: Range of Keyfob
« Reply #6 on: 07 April 2016, 22:09:00 »
i vaguely remember something on here about doubling the voltage by putting in two thinner cell batteries to replace the one.   try at your own risk/try on a spare - may damage your unit.
Re: Range of Keyfob
« Reply #7 on: 07 April 2016, 22:41:31 »
How about you try it and report back ::)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Range of Keyfob
« Reply #8 on: 07 April 2016, 22:48:27 »
 ;D ;D ;D ;D ;D ;D
Great plan that.  Or, wire it directly to the mains - You can unlock it from Zambia then!  ::)
Seriously though - I do see why you would want the car to respond to the key further away - When a thunder storm has set the alarm off, when the Missus needs to get something from the boot (and you are (like me) too bone idle to walk there), etc etc.
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
Re: Range of Keyfob
« Reply #9 on: 08 April 2016, 08:02:03 »
IME, range is not that important for locking/unlocking, as it is for closing windows via remote locking.
It proved to be a great feature when suddent and strong rain strucks, and your car is outside, with opened windows.
Mine has range of som 20m on open ground.
And yes, holding it next to your head increasses range noticably (don't know if the size of the head is a factor ;D ;D).
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Range of Keyfob
« Reply #10 on: 08 April 2016, 11:46:29 »
My MFL TD Estate responds better than my FL Elite saloon! ??? :y
omega2018
Re: Range of Keyfob
« Reply #11 on: 09 April 2016, 11:15:00 »
works fine just not sure I would leave them both in there hence the warning ::)
Re: Range of Keyfob
« Reply #12 on: 09 April 2016, 15:19:58 »
Then you haven't actually tried ::)
Re: Range of Keyfob
« Reply #13 on: 09 April 2016, 16:12:01 »
What a great idea - but would it not be better to connect it to a 12v car battery? ;D ;D ;D ;D ;D
There's certainly a waft of cattle around your post. ::) ::)
Re: Range of Keyfob
« Reply #14 on: 10 April 2016, 10:18:04 »
I would advise OOFers NOT to try this.  At best, range won't be improved unless your old battery is as flat as a witch's tit. At worse it will mean a new fob + programming.
