Author Topic: Air con help  (Read 6379 times)
Jazzyj123
  • Hemel Hempstead
    • Saab 9-5 2.3t Vector
Air con help
« on: 09 April 2016, 15:11:25 »
Need a bit of advice about dad's omega. He's taken it to have the headlights polished and the air con checked. They pressure tested the air con system and found it is leaking at one of the valves.
It's the valve circled in the picture below
There appears to be no valve inside the port. Just a ball cock. How easy is the valve to replace?
Re: Air con help
« Reply #1 on: 09 April 2016, 15:14:40 »
Very.  ;)
Takes 30 seconds, and regardless of what anyone says, the valve insert is available separately for less than a fiver... if garage wants to fit a new pipe then they should do so free of charge and they should pay for the pipe too as it's unnecessary to buy the complete pipe :y
Re: Air con help
« Reply #2 on: 09 April 2016, 15:52:16 »
Very.  ;)
Takes 30 seconds, and regardless of what anyone says,  ....
I was told by countless people that it was the whole pipe until I removed it to show thhem what i wanted. Andy C provided me with a part number while I was stood in my local Vauxhall dealer that had just told me the same as everyone else  :y :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Air con help
« Reply #3 on: 09 April 2016, 15:53:38 »
The valve you require is readily available from gm, it's called (high pressure valve), the one above it too the left is the (low pressure) and a normal tyre core will do, the switch in the top right is pressure switch, about £60.
There is a guide in the relevant section, of how to change said valves and the gm part numbers. :y
Hoof'land storeman.
Re: Air con help
« Reply #4 on: 09 April 2016, 15:53:50 »
You need a 17 mm spanner to support the fitting under neath while you use a 15mm socket in the valve itself (ask The Boy  ::) ::) ). The 15mm will be a tap on fit  :y
Re: Air con help
« Reply #5 on: 09 April 2016, 15:54:41 »
The valve you require is readily available from gm, it's called (high pressure valve), the one above it too the left is the (low pressure) and a normal tyre core will do, the switch in the bottom right is pressure switch, about £60.
If weere bothtalking the same valve, mine was about £5
biggriffin
Re: Air con help
« Reply #6 on: 09 April 2016, 15:57:20 »
That is the high pressure switch, just visible, with two wires going to it, the valve circled is indeed about £5.00. Hp valve :y
Hoof'land storeman.
Re: Air con help
« Reply #7 on: 09 April 2016, 16:01:14 »
52458177
Jazzyj123
  • Hemel Hempstead
Re: Air con help
« Reply #8 on: 09 April 2016, 16:26:19 »
So the part circled is the high pressure port and not the low pressure?
Either way will only cost a few quid to fix?
How do you put the valve in?
Re: Air con help
« Reply #9 on: 09 April 2016, 16:40:45 »
Reply #4
Jazzyj123
  • Hemel Hempstead
Re: Air con help
« Reply #10 on: 09 April 2016, 16:45:13 »
Reply #4
Sweet. Thank you all very much. It's odd that his car appears to have absolutely no valve in it at all at the moment
Re: Air con help
« Reply #11 on: 09 April 2016, 16:49:24 »
Reply #4
it's just a spring loaded ball ... very basic valve
Jazzyj123
  • Hemel Hempstead
Re: Air con help
« Reply #12 on: 09 April 2016, 16:52:36 »
Reply #4
Ah ok. The ball still appears to be there but the air is pissing out past it. Is that the valve that's goosed or something else?
biggriffin
Re: Air con help
« Reply #13 on: 09 April 2016, 17:10:20 »
Reply #4
The hp valve can be cleaned, with carb cleaner. But tin of that costs'. £3.00, new valve is only £5.00 :P
Hoof'land storeman.
Jazzyj123
  • Hemel Hempstead
Re: Air con help
« Reply #14 on: 09 April 2016, 17:25:28 »
I've already got some carb cleaner. Could it just be dirt caught in it then?
I guess it still needs removing for cleaning?
