Author Topic: Help with Check message, please.  (Read 7576 times)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« on: 12 April 2016, 15:05:31 »
Today I got "LOW BEAM FLD/VISION".
Can anyone tell me what it means, what to look for or what has gone wrong, please?
Ron.
Re: Help with Check message, please.
« Reply #1 on: 12 April 2016, 15:29:24 »
Check the toggle arm on the front n/s wishbone sensor hasn`t come adrift. Just off centre left in pic
« Reply #2 on: 12 April 2016, 16:32:18 »
Also same on nearside rear trailing arm ;)
dave-b
  • Wigan, Lancs.
    • Elite 3.0 F/L
« Reply #3 on: 12 April 2016, 17:01:55 »
I got this message when a headlamp motor failed. They usually fail in the 'down' position, so check the beam height against a wall, garage door or similar.
deviator
  • Chesterfield
« Reply #4 on: 12 April 2016, 17:32:15 »
I've had this message before, normally when the battery is a little weak. Does it come back on the next cycle after a run?
Bigron
  • Witham, Essex
« Reply #5 on: 12 April 2016, 17:34:30 »
Thank you for your replies, gents. I am about to show my ignorance in that I don't really know what has happened, what the fault is and is it serious?
If a sensor has come adrift, would this be due to the appallingly pot-holed state of our roads?
Could a fat bloke get far enough under with the car in the road to see the problem?
Ron.
deviator
  • Chesterfield
« Reply #6 on: 12 April 2016, 17:46:23 »
If you put full right hand down on the steering, you should be able to see the front sensor - front offside. The rear is a little more tricky, but IIRC you can just see it if you are willing to lay on the floor with a torch - rear nearside.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 12 April 2016, 17:50:53 »
The rear is much easier to check: run your trolley jack under the semi-trailing arm to fit new shocks.
Guaranteed diagnosis: yep, the headlight sensor is oppsed.
Hope this helps ;D
« Reply #8 on: 12 April 2016, 18:11:40 »
In order of likelihood, front sensor (as per pic above, and both lights are low), either servo motor (tends to show as one light very low, other stuck at a set height), rear sensor (both lights low).
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #9 on: 12 April 2016, 23:15:29 »
The plug/socket on mine is held together with a cable tie, have done it twice so far. ;)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #10 on: 12 April 2016, 23:20:39 »
Same message for me a while back. Renewed rear nearside sensor, all well to date :y
« Reply #11 on: 13 April 2016, 01:22:55 »
Or in my case on the old Estate, a break in the loom under front wing  ;)
Keith ABS
  • Maldon Essex
« Reply #12 on: 13 April 2016, 07:29:23 »
It was the arm on the rear f my estate that kept popping off with the essex road condition
Keith ABS
amba
  • Medway towns
    • German V6
« Reply #13 on: 13 April 2016, 07:37:17 »
Water had got into the plug socket at the front of mine and caused all the terminals to corrode.
New plug soldered onto loom,sensor pins cleaned with wet,n,dry then re-connected and to be sure problem doesnt occur again entire back of plug coated with a thick smear of black silicone to keep water atbay.
Been fine now for past 18 months :y
« Reply #14 on: 13 April 2016, 19:05:46 »
Where it rubbed on liner? Seen that a couple of times, but rare. Seen loom failures near front sensor as well.
