Author Topic: Three parts inside coolant bottle  (Read 3043 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 14 April 2016, 17:36:42 »
Hello
I was cleaning my coolant bottle by filling it with hot water and shaking etc. At the end I found three loose parts in the bottom of the bottle; two washers one metallic with big hole and one plastic one with small hole and then a float as well.
How to put them back and in which order. Do I miss some parts? Difficult to understand how the float is locked.
jimbo125
  • Camberley
    • Vauxhall Omega 2.5V6CDI
Re: Three parts inside coolant bottle
« Reply #1 on: 15 April 2016, 00:56:46 »
Oops :D
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 15 April 2016, 01:43:09 »
The Float clips / push fits on, sounds like you've furbed the whole thing.  ::)
If you ever come across those wooden ships in the bottles, leave them be.  ;D
polilara
  • Finland
« Reply #3 on: 15 April 2016, 10:51:48 »
So have to buy brand-new?
« Reply #4 on: 15 April 2016, 10:56:20 »
Yes .... but at least you end up with a nice shiney new bottle  :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #5 on: 15 April 2016, 11:00:02 »
They're alleged to be 'about £20' from the dealers. This is about a decade out of date, and minus the vat.
I think nearly £40 is the current price. I'd normally be fine recommending a low mileage used example, but if someone on here were to have one for sale, I'd imagine postage to Finland would bring it to about the price of one from you local Opel dealer.  :-\
I've got an excellent spare creamy one for sale, but it's from a 2.2 DTi, and doesn't have a level sensor in it.  :(
Agree with Andy above, probably best brand new.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 15 April 2016, 11:17:38 »
You could remove the broken float parts and bridge the wiring plug to turn off the warning light. That will save you about €50.
If you want it to work as designed, then a new tank is the way to go.
« Reply #7 on: 15 April 2016, 11:19:58 »
Good point nick. To the OP, if you fancy this route, like I say, I've got one here if it's any good.  :) Cars went about 100 years without coolant level sensors  :y
polilara
  • Finland
« Reply #8 on: 15 April 2016, 11:34:52 »
OK, thanks for all. I'll buy a new one, better to have the level sensor working as it is available. No need to open the bonnet too often.
« Reply #9 on: 15 April 2016, 12:46:11 »
That was before the HBV was invented, mind.
« Reply #10 on: 15 April 2016, 13:03:23 »
haha. Don't we do our weekly checks under the bonnet, gentlemen?  :y
jimbo125
  • Camberley
« Reply #11 on: 16 April 2016, 01:18:54 »
No most of my engine is on the shed floor waiting to go back in under the bonnet soon ;D ;D ;D
