Author Topic: Donut bushes  (Read 3327 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Donut bushes
« on: 18 April 2016, 19:57:50 »
So I thought I heard a rear spring go on me the other day. Had a butchers today and springs all good on front and rear fortunately. Wonder what the twang was that I heard.
Anyways I do think I need donut bushes. Quite a bad creaking from the rear passenger underneath when going over humps.
I've read the guide. Experience I've had though relatively limited tells me this job won't be that easy. I remember rear axle bushes on an Astra that were a nightmare even with good access.
Just looking at methods for getting these out. As I'll be on a ramp I figured I'd just blast them with my air hammer. Will this work? I remember on the Astra just hammering the hell out of them with a chisel bit in the air hammer and eventually they popped out.
Your thoughts. Just want to do it as easy as possible.
Oh and where does one purchase the bushes for them. I presume poly would work?
RIP Paul Lovejoy
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Donut bushes
« Reply #1 on: 18 April 2016, 20:13:49 »
My thoughts? In order:
You should let the passenger sit in the car 8)
Getting them out isn't too bad, I pried mine out with a claw hammer and then a pry bar. This was on axle stands although some more leverage would have been good. This won't be a problem on a ramp. Rather than spend ages hammering away if they don't come out, I would cut a couple of  slots in the case first.
The new ones slipped in easily after a good squirt of silicone spray.
AGP had them in stock, and were about £20 each
ted_one
Re: Donut bushes
« Reply #2 on: 18 April 2016, 20:19:18 »
Serek did mine a few days ago,up on the ramp,job took around 25 minutes,made it look easy :y
Webby the Bear
  • Northampton
Re: Donut bushes
« Reply #3 on: 18 April 2016, 20:29:25 »
Thanks boyos. Lol I'm always worried when I hear 'they're easy' lol
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: Donut bushes
« Reply #4 on: 18 April 2016, 20:32:31 »
Ps Nick, when u say cut slots in the case I presume u mean the bushing has a thin walled metal sleeve round it... Like the Astra axle bushes did that I mentioned
RIP Paul Lovejoy
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Donut bushes
« Reply #5 on: 18 April 2016, 21:09:50 »
Don't use silicone spray, allows bush to move once fitted, use a water based lube, bit of washing up liquid if you must.
Hoof'land storeman.
Re: Donut bushes
« Reply #6 on: 18 April 2016, 21:28:14 »
I used a screwdriver to get the damn thing going, I then rammed in a brake calliper tool. I expanded it so it pushed the old donut out, popped out a treat  :y
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Donut bushes
« Reply #7 on: 18 April 2016, 22:08:19 »
Washing up liquid is my preferred lube.
Shut your faces.
Webby the Bear
  • Northampton
Re: Donut bushes
« Reply #8 on: 19 April 2016, 18:48:05 »
That's a really good idea tunster. I presume u mean the calliper rewind tool? And the part shaped like a brake pad draws it out as the end pushes it out against the chassis?
RIP Paul Lovejoy
Re: Donut bushes
« Reply #9 on: 19 April 2016, 20:17:09 »
Yeah  :y
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Donut bushes
« Reply #10 on: 19 April 2016, 20:28:52 »
Did mine the other day, first side 1 hour other side 20 mins :y axle stands and crow/lever bars :y
amba
  • Medway towns
    • German V6
Re: Donut bushes
« Reply #11 on: 19 April 2016, 20:29:59 »
Large flat screw driver and a small crowbar is my prefered method.Done 8 of them this way all on axle stands and once they start its just a matter of keeping applied pressure as they remove as being thick rubber have a tendancy to retract on themselves whilst removing.
Universal lub from swearing is what I apply and after giving them a good thump to get back in they then can be fully pushed in with the triangular plate inverted and pumping up and down on a trolley jack does the job.
Ensure you fit them in the same orientation they were removed in as per the guide as they will not support properly if not
Re: Donut bushes
« Reply #12 on: 20 April 2016, 15:36:13 »
Shut your faces.
We heard your Mrs is a bubbly kind of girl!  :P  :y
