Author Topic: What's that ?  (Read 2251 times)
EMD
  • Noofhampton
    • 95t
What's that ?
« on: 19 April 2016, 10:51:59 »
As my first fl Im looking at the engine rad and between that and the ac rad
is a small rad  ??? Is that oil cooler  ??? Very different from my pf car .
What's the score , what's needed to be undone to get the engine rad out
and Will i lose any refrigerent  :-\
Omegatitis
serek
  • huntingdon
    • 3.2 mv6
Re: What's that ?
« Reply #1 on: 19 April 2016, 11:18:12 »
on 2.6 and 3.2 you got external gearbox cooler , that what is on you car
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: What's that ?
« Reply #2 on: 19 April 2016, 11:18:41 »
Its the transmission fluid cooler. On earlier cars it was built into the side of the coolant radiator.  :y
Edit. Beaten to it by 29 seconds.  ;D
« Last Edit: 19 April 2016, 11:21:01 by Migv6 »
EMD
  • Noofhampton
    • 95t
Re: What's that ?
« Reply #3 on: 19 April 2016, 11:23:44 »
Ah i see  :y Looks like that trans cooler lifts out with the rad then and also
looks like a different set up of pipes to the ac so won't lose any refrigerent.
Omegatitis
EMD
  • Noofhampton
    • 95t
Re: What's that ?
« Reply #4 on: 23 April 2016, 13:57:58 »
Thought it was all good until i noticed a coolant drip from underneath again  :( Top sensor is weeping  >:( I did put some ptfe tape on the thread and made sure it was tight but i think the copper washer is the priblem . Cleaned it up and put some sealant on so hopefully that will do it  ::)
Omegatitis
