Author Topic: These are good - Screwdriver bits, torx etc.  (Read 5516 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 20 April 2016, 20:39:10 »
Picked some packs up today, 32 Bits and a Drill Extension, works out at 3p per bit, £1 a Pack (Poundland).  :y :y :y
If like me, youve lost or ruined the bits/ bit holder from the Halfords Tool Kit, Ive cut one of the red holders down to fit with the bits I need to replace.
Ok, they might not last long, the Halfords ones didn't either, but Ive tried expensive Titanium ones in my drill and they dont last either.
http://www.poundland.co.uk/tommy-walsh-screwdriver-bit-set-33-pack
« Last Edit: 20 April 2016, 20:40:53 by zirk »
Re: These are good - Screwdriver bits, torx etc.
« Reply #1 on: 20 April 2016, 23:21:33 »
Bargain, I bought a couple of similar sets about a year ago, 40 piece I think for £1.99 :y
Cettainly some bargains out there.
« Reply #2 on: 21 April 2016, 03:04:24 »
Likewise, but got mine a few years back.  Well used now (well some of the bits, not all), and still ok.  Think I paid around £2 for my set.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #3 on: 21 April 2016, 11:06:43 »
Picked up one of them little drill attachment magnetic jobbies on the right of your pick, at a car boot sale, which means I can now click any of my driver bits into, when using the small ratchet. The absolutely ridiculous thing about the socket you get with the Halfords kit is it isn’t magnetic. Pretty stupid when you’re trying to undo a screw unless it’s perfectly horizontal, or pointing upwards.  ::)
Yes, the attachment will fall out as easily, but you’ve got more chance holding on to it, and also it’s a damn sight easier to find when you do drop it!  :y
zirk
  • Epping Forest
« Reply #4 on: 21 April 2016, 11:11:40 »
Not got an old speaker kicking around, leave your bits on the magnet for a while.  ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 21 April 2016, 11:48:56 »
It does come with a spring to retain the bit, which works well for the first 3.5 times you use it.
« Reply #6 on: 21 April 2016, 13:28:16 »
Spring?? As you say, if I had one, I must've not realised I had it, and now it's clearly gone  :o
Will do the old knackered speaker idea.  :y
zirk
  • Epping Forest
« Reply #7 on: 21 April 2016, 13:32:28 »
Doesn't have to be knackered, a good would still do it,  ;D  ;)
« Reply #8 on: 21 April 2016, 13:50:50 »
"magnetic telescopic screwdrivers" (google it, loads to choose from)  are a great addition to the tool box as well :y
« Reply #9 on: 21 April 2016, 16:39:11 »
I only say knackered as they're the only type of speaker I possess  8)
Picked up a screwdriver with the magnetic socket attached, too. an amazing £1 from a 2nd hand hop up the road. Payed for itself after the first use  :)
78bex
    • 2.2 CD AUTO / FAZER 600
« Reply #10 on: 21 April 2016, 23:32:45 »
Don`t buy their screw sets, tried to pump a few of their 3 inch screws into a fence panel last weekend
Even on a low torque setting my drill chewed the face of the screw before it was halfway into softwood
jimbo125
  • Camberley
    • Vauxhall Omega 2.5V6CDI
« Reply #11 on: 21 April 2016, 23:55:46 »
Have done similar but they came in  plastic molded tubs and have had them several years and they still work. Not everything has to be snapon grade ;)
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
« Reply #12 on: 22 April 2016, 10:08:57 »
My only issue with the Halfords so far is the lack of magnetism, as said, and the consequential loss of one so far. Now replaced. Spending a few seconds checking which bit properly fits the screw in question, be it philips or pozidrive (which many people still think are the same) then using care when undoing. Best practice and all that.
And then the old rusty screw still rounds, but the theory is there  :D
« Reply #13 on: 22 April 2016, 19:31:41 »
32+1 Piece
Different tips from the normal ones
  • Chatham, Kent
« Reply #14 on: 22 April 2016, 20:46:36 »
And there's the Japanese equivalent, which is different again.
