Author Topic: Oil filter cannister  (Read 2292 times)
gbh
  • forest of dean
    • omega cdx 2.6
« on: 21 April 2016, 21:03:17 »
Does the O ring need replacing after taking cannister off?and if so where to get one?is it the same size as the cannister lid O ring?
Re: Oil filter cannister
« Reply #1 on: 21 April 2016, 21:19:21 »
If it's hard or cracked/split then it needs replacing.
Completely different size to cap seal.
« Reply #2 on: 22 April 2016, 09:02:24 »
Never ever needed to replace one personally, they are quite a complex rubber as I did buy one and Elite Pete had it when he damaged one on removal.
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #3 on: 22 April 2016, 21:38:19 »
if you've removed the filter housing why not convert to spin on? http://www.omegaowners.com/forum/index.php?topic=90579.0  the adapter is probably not much more than the o ring.
  • Online Online
« Reply #4 on: 22 April 2016, 22:13:58 »
if you've removed the filter housing why not convert to spin on?  ....
cos there's nothing wrong with the original design .......
both my Smart & Merc both have a replaceable filter type oil filter, though the housing are both plastic ...... never even looked at the Shitroen's  :-X
