Author Topic: A spot of maintenance  (Read 1662 times)
Markjay
  • London
« on: 28 November 2006, 14:11:29 »
I noticed recently that a metallic clong has developed from the base of the auto gear selector when going over bumps in the road (of which there are many in London). I took off the leather cover and had a closer look, and saw traces of lubricant covering the moving parts – so I took some ordinary multipurpose grease and smeared a fine layer on the lower toothed bit and especially on the plunger at the bottom of the stick – the one you move by pressing the lever on the gear knob – and it’s all nice and quiet now. Just something else to look at…
Alas, no more Omegas....
STMO123
Re: A spot of maintenance
« Reply #1 on: 28 November 2006, 14:54:35 »
Yes, multipurpose grease is graet for fixing 'clongs'. However, DO NOT try to use it on 'clanks' or 'clunks', these require specialised lubricants :y
« Last Edit: 28 November 2006, 14:57:53 by STMO123 »
Markjay
  • London
« Reply #2 on: 28 November 2006, 16:10:46 »
Yep, these are different products:
www.acmeclankslube.com
www.acmeclunkslube.com
 ;D
Taxi_Driver
« Reply #3 on: 28 November 2006, 19:04:26 »
 ;D
 ;D ;D
Or you could try this site
www.AAsacmeclankandclunklube.com
« Last Edit: 28 November 2006, 19:04:52 by Taxi_Driver »
« Reply #4 on: 28 November 2006, 19:24:33 »
Will not go on any AA site unless AA himself tells us them ;) ;D
