Author Topic: Screen washers & pump  (Read 3293 times)
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« on: 22 April 2016, 13:05:32 »
I had to clean the little filter which the screen washer pump sits on, as mounted on the washer bottle at the front of the car. After only 2 months the black gunge had come back with a vengeance, so both pumps out (screen & headlight) and a good flush out will hopefully keep the mouldy black stuff at bay. Just wondered if a drop of bleach added to the fluid may help, or not? Is there an anti-mould additive available, or just a matter of keeping things clean with regular flushes?
On a similar note, it appears the same pump provides water to the front screen and rear screen (estate), depending on which lever is operated on the column.... so the question - is there a solenoid valve or something which directs the flow of water to the front or the back, depending on which operation is selected?
Omega 2.5 V6 Facelift Estate.
Diamond Black Geezer
    • & a silly coupe coming...
Re: Screen washers & pump
« Reply #1 on: 22 April 2016, 13:17:13 »
I believe screenwash includes an anti-mould additive ad well as detergent. Are you using screenwash? If so, worth changing to another brand?
I confess I have no screenwash in mine at present, and haven't for a while and show no mould/gunge buildup. I did (at great annoyance to my missus) fill it with some white vinegar, to descale, dissolve, and flush out and rubbish that had build up in the last 20 years. That was maybe 3 months ago. I'd recommend anyone try the same, it's pence to do, smells a bit for a few days, but you're guaranteed a fresh set of hoses, and the vinegar won't attack and rubber or plastic which certain cleaning products will.
« Reply #2 on: 22 April 2016, 13:29:22 »
Just use a decent screen wash and you won't get a build up of gunge
« Reply #3 on: 22 April 2016, 13:37:40 »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 22 April 2016, 13:50:50 »
Most estate / hatchback pumps are dual pipes, by revering the voltage to the pump sends it to one or other.
Tick Tock
  • Hereford
« Reply #5 on: 22 April 2016, 14:07:48 »
Thanks for the replies. Concentrated washer fluid (cheap stuff) almost gone now, but if the black stuff comes back will try the vinegar  :y
zirk
  • Epping Forest
« Reply #6 on: 22 April 2016, 14:13:46 »
Try a few squirts of this stuff everytime you fill up, -
http://www.poundland.co.uk/astonish-mould-mildew-remover-750ml
Its good gear I use it everywhere, screen wash, Bathroom, Kitchen, Dishwasher stained Tea cups, PVC Window Frames etc, it take a while to kick in, but when used regularly it really does clean stuff up and stop mold, mill-due etc, cant recommend it enough.
Contains a tad of bleach so be careful with clothes etc.
Tick Tock
  • Hereford
« Reply #7 on: 22 April 2016, 14:23:41 »
Poundland - one of my favourite shops   8)
« Reply #8 on: 22 April 2016, 21:11:33 »
Thanks for the replies. Concentrated washer fluid (cheap stuff) almost gone now, ....
and herein lies your problem. As above, use DECENT screen wash and you won't get the gung
Tick Tock
  • Hereford
« Reply #9 on: 22 April 2016, 23:04:54 »
Ahhhh.... but in my defence, the cheap stuff might not have already been in there, just the cheap stuff topped up today.
What might be pertinent is the fact the tank was low, so a lot of air / oxygen to help the gunge grow?  :-[
