Author Topic: Wing  (Read 7167 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Wing
« on: 22 April 2016, 13:32:06 »
Thanks to a nice old lady  >:( >:( I need to swap the n/s wing...
Take it that its all bolt on... apart from the bolts along the top,where abouts are the others..  :y
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
Re: Wing
« Reply #1 on: 22 April 2016, 14:10:40 »
There are 2 X 10mm hex screws at the bottom of the wing - you'll need to remove sill cover..... and any attachment to the wheelarch liner of course.
Omega 2.5 V6 Facelift Estate.
Tick Tock
  • Hereford
Re: Wing
« Reply #2 on: 22 April 2016, 14:19:25 »
Diamond Black Geezer
    • & a silly coupe coming...
Re: Wing
« Reply #3 on: 22 April 2016, 14:21:05 »
Colour?  :)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Wing
« Reply #4 on: 22 April 2016, 14:22:55 »
Steve B
  • Leicestershire
Re: Wing
« Reply #5 on: 22 April 2016, 14:36:01 »
Re: Wing
« Reply #6 on: 22 April 2016, 14:50:13 »
;D keep going...
At least two more on the back edge... top one done from the door side, not as easy as it sounds...
Second one is about halfway down back edge... remove arch liner, then sound deadening foam and you can get to it.
Headlight and trim piece off, front bumper also off (at very least undone and pulled out/down on that side) as there's another 3 or 4 screws there ;)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: Wing
« Reply #7 on: 22 April 2016, 19:31:27 »
;D keep going...
What can possibly go wrong  :D
Steve B
  • Leicestershire
Re: Wing
« Reply #8 on: 22 April 2016, 19:34:21 »
i thought that too.... think answer is sill clips and headlight fittings  :-\
Re: Wing
« Reply #9 on: 22 April 2016, 19:55:40 »
Headlight is three bolts, lower one is visible/accessible either from underneath or with a long 1/4" extension once the trim is off.
Sill is a piece of piss... one torx screw under the front corner and seven or so pop caps along the bottom edge... Then, with the wheel on full left lock for nearside (opposite for offside), simply tap the sill cover forward an inch or so and it simply falls off :y
What you find underneath it once removed is a whole different conversation ;D
EMD
  • Noofhampton
    • 95t
Re: Wing
« Reply #10 on: 22 April 2016, 20:39:33 »
 ;D
Omegatitis
Steve B
  • Leicestershire
Re: Wing
« Reply #11 on: 23 April 2016, 00:07:30 »
It will look brand new  :y cheers for the howto Al  :y
Steve B
  • Leicestershire
Re: Wing
« Reply #12 on: 28 April 2016, 20:16:41 »
;D keep going...
Think i will take the bumper completely off owing to the fact that ive just gone and trashed the other front wing on a "No Exit" sign in a tesco car park.  ::)
EMD
  • Noofhampton
    • 95t
Re: Wing
« Reply #13 on: 29 April 2016, 12:35:23 »
;D keep going...
Like bumper cars up in Leicester land  :o
Omegatitis
Steve B
  • Leicestershire
Re: Wing
« Reply #14 on: 29 April 2016, 18:19:22 »
Went up to nigel today and got a pair of front wings off him... Great condition..And he is stripping another one on his drive the same colour ready for the next time  ;D ;D ;D  Pm you mr EMD  :y
