Author Topic: Exhaust stud nuts  (Read 2962 times)
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Exhaust stud nuts
« on: 24 April 2016, 02:29:21 »
Hey guys
I'm very soon going to have all the studs replaced as I have 2 sheared studs by the thermostat housing,  my question  is what is better to use a copper flashed steel nut or an aerotight nuts also stainless
Cheers
e46 325i se - 1.8vvti avensis liftback
Re: Exhaust stud nuts
« Reply #1 on: 24 April 2016, 10:32:48 »
Stainless studs, copper nuts
frostbite
    • 00' e46 325i se
« Reply #2 on: 24 April 2016, 11:47:28 »
Ok that was simple,  any particular style normal nut or a shouldered one or a BMW MINI turbo self lubing nut http://www.pelicanparts.com/More_Info/11657559557.htm?pn=11-65-7-559-557-M26
« Reply #3 on: 24 April 2016, 15:21:53 »
Get the GM ones
frostbite
    • 00' e46 325i se
« Reply #4 on: 24 April 2016, 16:57:37 »
I have found a kit from Germany, 2 gaskets 14 studs 10 nuts and a manifold for 80 odd pound
That way I can get the new manifold ground flat to hopefully cure the studs shearing
« Reply #5 on: 24 April 2016, 17:00:41 »
For a 2.0ltr as the 2.2`s are different
frostbite
    • 00' e46 325i se
« Reply #6 on: 24 April 2016, 17:25:54 »
X20xev same for the vectra b and frontera. Also has the SAI holes so is a straight swap
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 24 April 2016, 19:15:07 »
I bought 16 M8x40(which seems to be a standard size) studs and copper nuts plus similar M10 nuts for the downpipes, for my V6 which cost less than a fiver.
frostbite
    • 00' e46 325i se
« Reply #8 on: 25 April 2016, 06:47:22 »
This includes a new manifold and gaskets hence the price,  if there weren't any flaw with the casting I wouldn't have bothered
artsoul_no1
  • sidcup, kent
    • Omega CD 2.6 v6 2002
« Reply #9 on: 25 April 2016, 12:11:33 »
NICK W PM sent  :y
