MOT reminder
Started by Shackeng, 04 May 2016, 16:49:30
TD
Quote from: Shackeng on 05 May 2016, 10:28:09
Quote from: TD on 05 May 2016, 09:07:17
Quote from: Shackeng on 05 May 2016, 07:55:13
I'm annoyed because I always used to get a reminder from the VX dealer, who used to do it for £29! Now taken over, no reminder and £50!!! >:( >:( >:(
If you fancy a trip to Swindon, you can get an MOT for £25  ;)
Spooky, I've just booked in to Now VX Hillmead for £35!, a bit better than Marlborough. :o They will also try to find where the AC gas is escaping, as after checking the compressor, HP & LP valves, all changed last year, there is no sign of a leak there or anywhere else. Hopefully they may have something to detect leaks. I'm somewhat miffed that they list the car as Vauxhall OLD MODEL, in capitals on the booking e-mail. :y :y :y
Probably a squirty bottle filled with water and washing up liquid...spray everywhere and look for the bubbles  ::) ;D
Quote from: TD on 05 May 2016, 12:21:39....
Refrigerant leaks are unlikely to show up like that. Hopefully the last time it was refilled, it had dye added which they look for using u/v glasses  :y
TD
Quote from: Andy B on 05 May 2016, 12:55:03
I would hope that they will pressure test the system with nitrogen first, then look for the bubbles.....
Using a U/V light to look for the dye needs to be done really on a fresh leak.
You can also use a 'sniffer' to try to find the leak, but you need a fairly draught proof area to have much success.  :)
Shackeng
Quote from: Andy B on 05 May 2016, 11:26:23
Quote from: Shackeng on 05 May 2016, 10:28:09.....
Is that a reference to your car or you Chris?  ::) ::)  ;) ;)
I deeply resemble that remark! :P :y
Quote from: Shackeng on 05 May 2016, 18:46:01
:y :y ;)
