Author Topic: Battery change  (Read 2471 times)
kevinp58
  • kent
    • 2002 3.2 elite
Battery change
« on: 04 May 2016, 21:33:37 »
The old battery has had its day I got a nice new 096 yuasa 5000 from autosessive for £70 delivered now my question is do I need to do anything in prep I have the car pass will I need to reprogram anything other than the radio unit it is a late 02 3.2 elite. thanks
Re: Battery change
« Reply #1 on: 04 May 2016, 21:47:35 »
You have 15 secs from turning the ignition off to disconnecting the battery otherwise the alarm sounds. Best to slacken the battery negative in readiness, turn the ignition off & then remove the neg/earth lead.
Windows ..... press & hold each switch in the up posn till you hear a click
Roof ..... if applic ..... turn roof switch to each major position, push & hold till all movement stops
If all else fails Please read the manual ..... it is in there  ;) ;) ;)
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Battery change
« Reply #2 on: 04 May 2016, 23:26:45 »
If you have a booster or a spare batt and jump leads, you can change the batt without worrying about the alarm and loosing codes
e46 325i se - 1.8vvti avensis liftback
Re: Battery change
« Reply #3 on: 04 May 2016, 23:28:30 »
Thats exactly what I do  :y
Have in the past successfully used junp leads off new battery!
kevinp58
  • kent
    • 2002 3.2 elite
Re: Battery change
« Reply #4 on: 05 May 2016, 22:00:38 »
Thanks for the replies I will change it at the weekend  :y :y
kevinp58
  • kent
    • 2002 3.2 elite
Re: Battery change
« Reply #5 on: 07 May 2016, 21:45:34 »
done the battery with the jump lead method and worked well thanks guys  :y
