Author Topic: CDX Heated Seats - Do all year have them ?  (Read 3290 times)
Hudson
« on: 05 May 2016, 18:54:11 »
Looking at a Y reg 2.2 CDX estate and the owner says it does not have heated seats fitted.... i thought every CDX had them ?
Re: CDX Heated Seats - Do all year have them ?
« Reply #1 on: 05 May 2016, 19:17:09 »
It should have... Wiring connection at side of seat under slide out trim piece will confirm... Two yellow plugs are side airbag and pretensioner, large black plug with red and brown wires is main power feed for height motor, small black plug is seat heating.
Switches will also be present... Note seller might have said no to cover the fact that they don't work ;)
« Reply #2 on: 05 May 2016, 19:18:03 »
To add, rear heated seats are retrofit only, and not a factory option...
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #3 on: 05 May 2016, 22:09:26 »
Cdx should have heated thrones,  hell my first mig 96 plate cdx had front heated cloth seats
e46 325i se - 1.8vvti avensis liftback
Hudson
« Reply #4 on: 05 May 2016, 22:23:44 »
I thought so...... the car is a lot of miles away so checking wires before going is not an option ........ odd indeed.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #5 on: 06 May 2016, 07:05:47 »
You could always ask if there's an oofer near to where car is and if they could go have a look at it for you.
Hudson
« Reply #6 on: 06 May 2016, 08:16:00 »
Good idea :)
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #7 on: 06 May 2016, 10:41:20 »
yeah right like a car without heated seats is worth more than one with ones that don't work and might just need a new fuse.  ;D
« Reply #8 on: 06 May 2016, 13:01:20 »
???  :-X
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #9 on: 06 May 2016, 13:23:20 »
My 94 CD had heated seats so surely your newer CDX should have them. ???
2boxerdogs
« Reply #10 on: 06 May 2016, 13:32:10 »
My CDX had them worked perfectly, but in 5 years of ownership used them about 3 times.
« Reply #11 on: 06 May 2016, 20:00:38 »
I frequently use mine  :y
