Author Topic: Broken Down 2.6  (Read 6723 times)
star_whites
  • Rotherham
Broken Down 2.6
« on: 06 May 2016, 08:31:39 »
Ok here's a weird one for you with more knowledge. 2.6 auto 2001.
I was driving along at 30 when we entered the 60 zone I accelerated slightly and the whole engine cut out. No eml light on so I just rolled it into the nearest entrance and tried to restart. The engine just turns over and does not fire at all.
Turned ignition off and back on and I noticed the eml is not lighting up at all even on just turning the ignition on which I thought it did. Tried pedal check and still no eml. Car still just turning over like there's no fuel however I've just put £40 in and yes I've checked the receipt it was petrol lol
I've phoned green flag to get her sorry butt dragged home but with no eml I have no idea where to start, any ideas ???
Re: Broken Down 2.6
« Reply #1 on: 06 May 2016, 08:40:05 »
Crank sensor would be my starter for ten :-\
Wait a while and try to restart it... you could wait for recovery first, as it may cut out again in short order if you do get it going...
« Last Edit: 06 May 2016, 08:41:41 by Harris K Telemacher »
star_whites
  • Rotherham
Re: Broken Down 2.6
« Reply #2 on: 06 May 2016, 08:44:07 »
Ok I'm sat waiting for Green Flag so though as eml is not on if check all the connections around the fuse boxs. Found the large green 30a fuse blown in first black box that Is situated above the battery. I'm guessing this is significant.
I'm guessing this is significant and may answer the reason why the eml light is not coming on
Re: Broken Down 2.6
« Reply #3 on: 06 May 2016, 08:49:12 »
Wrt pedal trick, it's the Spanner Light which flashes... no flashing means no/dead bulb :-\ The EML has either blown or been removed to mask precat issues...
Possible... swap with the right hand 30A maxi fuse from under the steering wheel and report back...
Incidentally is that the fuse nearest the engine or nearest the wing?
star_whites
  • Rotherham
Re: Broken Down 2.6
« Reply #4 on: 06 May 2016, 09:24:26 »
Oh mechanic arrived and went for new fuse. Replaced fuse turned ignition on and it blew immediately.
Fuse is the one in the carrier that is directly above the battery. There is far be fuses in total in there, and it's the only 30 amp
Re: Broken Down 2.6
« Reply #5 on: 06 May 2016, 09:36:24 »
I'm sure we've seen this before...  :-\
I assume you have turned off all electrical loads before installing the new fuse?
« Last Edit: 06 May 2016, 09:39:09 by NewbieDocker »
star_whites
  • Rotherham
Re: Broken Down 2.6
« Reply #6 on: 06 May 2016, 09:39:49 »
Yes, everything was turned off and keys were not in the ignition.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Broken Down 2.6
« Reply #7 on: 06 May 2016, 09:40:44 »
Had this happen, changed fuse, went pop, check main feed from battery isn't shorting due to chaffing on body,
Hoof'land storeman.
Re: Broken Down 2.6
« Reply #8 on: 06 May 2016, 09:41:34 »
I knew I'd heard it somewhere!
biggriffin
Re: Broken Down 2.6
« Reply #9 on: 06 May 2016, 09:46:18 »
Also starter solenoid, were the supply bolts on, nut comes lose, live touch's block, :'( pop goes fuse,.
Hoof'land storeman.
star_whites
  • Rotherham
Re: Broken Down 2.6
« Reply #10 on: 06 May 2016, 12:52:07 »
Well she's now home and on the drive, plus I've now got 10 spare fuses but the old girl will have to wait until tonight/tomorrow for more investigation as at work.
I will start tracing cables back and report back later. Just hope the rain holds off.
Re: Broken Down 2.6
« Reply #11 on: 06 May 2016, 14:13:43 »
Start with tracing the +ve from the battery... If it's blowing with everything off then it's unswitched ;)
star_whites
  • Rotherham
Re: Broken Down 2.6
« Reply #12 on: 06 May 2016, 15:14:20 »
It actually blows as you turn the ignition on and crank the engine.
Re: Broken Down 2.6
« Reply #13 on: 06 May 2016, 15:15:30 »
The 30A fusible link feeds the ECU itself, the main and fuel pump relays (purple ones in the box by the battery), the fuel pump wiring and also the 12V feed to all the engine electronics.
I would check all wiring around the engine for possible shorts - feeds to the injectors, multiram and canister purge solenoid valves, Lambda sensor wiring, cam sensor, MAF sensor and coolant temperature sensor. All are fed from this fuse. I wouldn't mind betting some of the wiring has chafed and shorted out somewhere.
star_whites
  • Rotherham
Re: Broken Down 2.6
« Reply #14 on: 06 May 2016, 18:25:11 »
Ok, home from work and now looking at he old girl. Straight away found second 30amp gust in fuse box next to the wing also blown so that's one blown in each fuse box.
