Author Topic: Cam cover query  (Read 2723 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Cam cover query
« on: 07 May 2016, 13:22:12 »
Hi all,
Just noticed that there is oil weep from some of the bolts that hold the cam covers on. I am going to clean the breathers again.
In your opinion fellas, is it worth checking the tightness of the bolts, or are they best left alone. I can't see any leaks at all from the covers anywhere else, and I don't want to start things leaking.
Opinions welcomed :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Cam cover query
« Reply #1 on: 07 May 2016, 14:40:01 »
I can't see any harm in checking bolt tightness-as long as you don't get tempted to give them an extra "tweak" and just stay with the correct torque value.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Cam cover query
« Reply #2 on: 07 May 2016, 15:44:22 »
Cheers, Baz....I have the torque wrench. Knowing how critical these torques are and the gaskets, I thought I had to ask the question :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Cam cover query
« Reply #3 on: 07 May 2016, 16:17:51 »
Also worth taking the bolts out, giving the holes a clean with brake cleaner to get rid of the oil and then dipping the bolts in black sealant and torqueing them back down as said Tony  :y
Don't forget to give the breathers a bloody good clean though as that's probably the cause of the leak anyway  :y
« Last Edit: 07 May 2016, 16:19:30 by tigers_gonads »
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Cam cover query
« Reply #4 on: 07 May 2016, 18:03:36 »
Cleaning the breathers now TG....giving them a really good soak and a blow through with the compressor. The little tiny holes are all clear.
I know there is a guide on doing the box on the other end of the hoses, but its not easy to get at, is it. :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Cam cover query
« Reply #5 on: 07 May 2016, 19:27:37 »
Depends on if your belly gets in the way when your leaning over it  :-X :D :D
Once past the gut problem, i've got a whopping big syringe which I use for emptying the plug wells out with.
It came with a big needle and 2ft of pipe so with a little brake cleaner in the syringe, its great for poking in there and blasting / sucking out any crap :y
Just got to make sure you don't stick too much in there or you end up having to change the oil  ::)
Re: Cam cover query
« Reply #6 on: 07 May 2016, 20:52:56 »
Doing breathers is entirely pointless without cleaning the breather box ports too especially the small pin prick hole :y
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Cam cover query
« Reply #7 on: 07 May 2016, 21:01:44 »
Ironically, that does play an important part !!!!!!! :( When you say blast with cleaner, what do you call 'don't overdo it'
« Last Edit: 07 May 2016, 21:03:37 by terbert »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Cam cover query
« Reply #8 on: 07 May 2016, 21:08:41 »
A quick blast of cleaner won't do the oil any harm  :)
Just don't pour the stuff in  ;D
