Author Topic: injectors  (Read 6648 times)
laney101
  • liverpool
    • omega elite v6
injectors
« on: 09 May 2016, 12:09:19 »
Im wanting to get a spare pair on injectors to have them cleaned and then swap mine out
Queation is is there any difference between 2.5,2.6.3.0and 3.2 injectors some blue some grey...
And is there any benefit to fitting blue ones from 2.5/3.0 to my 3.2?
Re: injectors
« Reply #1 on: 09 May 2016, 12:22:58 »
No because they're smaller ;) one of the reasons the 2.6/3.2 is marginally less economical...
laney101
  • liverpool
    • omega elite v6
Re: injectors
« Reply #2 on: 09 May 2016, 18:38:30 »
So the 2.5 and 3.0 injectors have a smaller flow rate.. is that at same pressure or different pressure
Re: injectors
« Reply #3 on: 09 May 2016, 19:18:20 »
Non DBW cars run a fuelrail pressure of 3.0 bar, DBW cars are at 3.5 bar :y
Re: injectors
« Reply #4 on: 09 May 2016, 19:39:13 »
Got a set of injectors on the 3.2 breaker :)
Re: injectors
« Reply #5 on: 09 May 2016, 20:25:48 »
Would hope OP has a set on his too, but you never know... might be a sale nonetheless  :D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: injectors
« Reply #6 on: 10 May 2016, 07:20:14 »
Now I seem to recal, don't fit 3.2 injectors to a 3.0, as they drip. But a 3.2 regulator in a 3.0 is good.
Don't know what 3.0l injectors in a 3.2 be like :-X
Hoof'land storeman.
Re: injectors
« Reply #7 on: 10 May 2016, 16:47:58 »
Vectra/Insignia VXR injectors and regulator will get more fuel in, but good luck getting the ecu to keep up...
biggriffin
Re: injectors
« Reply #8 on: 10 May 2016, 17:05:26 »
You need to get more air in too, or you just get unburnt fuel, washing down the bores. Or filling up the pre-cats and causing flames out the back,,,,circa late 80's touring and rally cars..
« Last Edit: 10 May 2016, 17:08:02 by biggriffin »
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: injectors
« Reply #9 on: 10 May 2016, 17:21:12 »
I wonder if the next question will ask which hotter/colder/shinier/gimmicky sparkplug is 'better'?
biggriffin
Re: injectors
« Reply #10 on: 10 May 2016, 17:44:42 »
Or which air-filter,, (KN,piper-cross, or big cone strapped to the airflow meter.
Hoof'land storeman.
laney101
  • liverpool
    • omega elite v6
Re: injectors
« Reply #11 on: 10 May 2016, 22:31:42 »
Not really no and arsy sarcasm isn't welcomed
Who mentioned vxr injector because I didn't? They Wouldnt ever be of any use. be high flow rate for turbo application.
I asked about 3.0/2.5 because got offered a set simply seeing if same flow rate and work ok .. They aren't same so all good I'll hold out for 3.2 injectors
Altering spark plugs only good if altering thermal efficiency of engine or running forced induction to get right burn.
Air filter pointless half the time a cone will cause heat soak and a updated panel filter will kill a man sensor or not be as efficient as a genuine one
baggers
  • Heywood, Mcr
    • Omega 3.0 & 2.2
    • Carlton, Senator, Omega Spares.
Re: injectors
« Reply #12 on: 10 May 2016, 23:16:25 »
Re: injectors
« Reply #13 on: 10 May 2016, 23:23:24 »
Why ??? Surely your 3.2 already has 3.2 injectors...
It's comments like that which encourage the sarcastic responses... A bit like saying I want a replica stock exhaust in stainless but want it to sound different and have a cross flow pipe... :-X
    • 530D M Sport, 330i Coupe
Re: injectors
« Reply #14 on: 10 May 2016, 23:31:18 »
........kill a man sensor......
Not being sarcastic but that mistype made me laugh, the ideal sensor to be fitted to a young lady's first vehicle.  :D
