Author Topic: temp going up  (Read 2005 times)
ShazC
  • Shropshire
    • Omega 2.2 51 reg
temp going up
« on: 09 May 2016, 19:55:40 »
hi all
Can anyone let me know why my car has started getting hot regarding temp espvially when standing ? i put the auto button on as climate control but does not make a great difference if i put the heater on hot the temp comes down any surgestions anyone   2.2 diesel on 51 plate
thanks ShazC
Re: temp going up
« Reply #1 on: 09 May 2016, 20:08:57 »
What temp is going up? Engine temp or cabin temp?
ShazC
  • Shropshire
    • Omega 2.2 51 reg
Re: temp going up
« Reply #2 on: 09 May 2016, 20:16:31 »
engine temp flucterating from just over half tp just under half normally
Re: temp going up
« Reply #3 on: 09 May 2016, 20:23:00 »
I'd suggest a stuck thermostat then.  :-\ Unfortunately there's not much in the way of guides for the 2.2 diseasal  :-\
Re: temp going up
« Reply #4 on: 09 May 2016, 20:31:52 »
Auto button is for cabin fan speed...
Aircon on, you should have all three radiator fans running at low speed... if temperature rises, front and rear fans switch to high speed as dictated by the two thermoswitches on the radiator :y
There's a guide for checking the radiator fans :y
ShazC
  • Shropshire
    • Omega 2.2 51 reg
Re: temp going up
« Reply #5 on: 09 May 2016, 20:40:15 »
thanks are the switches actually on the radiator?
Re: temp going up
« Reply #6 on: 09 May 2016, 22:59:42 »
Yup :y
Battery end/side...
