Author Topic: Elite rear springs  (Read 16169 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Elite rear springs
« Reply #30 on: 12 May 2016, 16:20:57 »
No prizes for guessing the make of the springs removed. Interesting though is that the new Sachs springs are 28mm sorter than the KYB ones removed. The box says they are for the Omega 94 to 04. I assume they are OK.   :-\
jb
  • bucks
    • 3.2 Elite
« Reply #31 on: 12 May 2016, 16:44:14 »
They are fine although a little softer than the std non sl gm springs. Assume you got them from euro car parts.
Shackeng
  • Ramsbury
« Reply #32 on: 12 May 2016, 19:05:33 »
Correct, Road test was OK, and anyway soft is good for an old fart like me. ::)
« Reply #33 on: 12 May 2016, 20:38:07 »
Unless they're estate ones :-\
Shackeng
  • Ramsbury
« Reply #34 on: 12 May 2016, 22:15:10 »
Don't think so, as they were reg related.
« Reply #35 on: 12 May 2016, 22:36:56 »
What length the old ones? Have a set of Estate ones at home, so can cross check :y
Shackeng
  • Ramsbury
« Reply #36 on: 13 May 2016, 16:24:09 »
KYB 278mm.
« Reply #37 on: 13 May 2016, 16:40:36 »
KYB 278mm.
Will measure into morning :y
« Reply #38 on: 18 May 2016, 07:33:54 »
Shackeng
  • Ramsbury
« Reply #39 on: 18 May 2016, 09:56:01 »
Strange that there should be varying lengths. :-\
« Reply #40 on: 18 May 2016, 11:15:17 »
Wear and tear together with different manufacturers I guess :-\ spring thickness and number of coils probably also play a part... Might also explain more frequent breakages of certain springs...
Shackeng
  • Ramsbury
« Reply #41 on: 21 May 2016, 15:06:42 »
Certainly the KYB had reducing thickness at the ends, and were required to be fitted one way up. Sachs were same thickness throughout, and appeared symmetrical top and bottom, with no "this end up" instruction. :y
« Reply #42 on: 21 May 2016, 15:31:02 »
Genuine are same as Sachs in design...
Shackeng
  • Ramsbury
« Reply #43 on: 21 May 2016, 15:34:41 »
Nice to know. But what about length? :-\
« Reply #44 on: 21 May 2016, 15:35:33 »
Reply #38 :y
Pages: 1 2 [3] 4  All   Go Up
