Author Topic: Front discs  (Read 4045 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Front discs
« on: 21 May 2016, 22:23:29 »
Im I correct in thinking that the 2.5 v6 will use the same discs as a 3.2 ?
Re: Front discs
« Reply #1 on: 21 May 2016, 22:42:16 »
Yup  :y
295x28 iirc...
Migv6 le Frog Fan
Re: Front discs
« Reply #2 on: 21 May 2016, 22:46:40 »
Thanks. :y
Re: Front discs
« Reply #3 on: 21 May 2016, 23:05:22 »
Fronts only as per Op`s "Q". Rears are vented on 2.6/3.2 but he probably knows that being a "member of old" :D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Front discs
« Reply #4 on: 22 May 2016, 02:16:16 »
He's a newbie from the "Arse end of nowhere" what does he know, jack shite,  ;D
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Front discs
« Reply #5 on: 22 May 2016, 15:00:15 »
Yup  :y
295x28 iirc...
Perhaps a slip of the digit, but shouldn't that be 296x28?
Re: Front discs
« Reply #6 on: 22 May 2016, 20:44:36 »
Yup  :y
295x28 iirc...
And the rears are 286x12/20 non/vented...
I can never remember which is ..5 and which is ..6 :D
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Front discs
« Reply #7 on: 23 May 2016, 07:25:08 »
Just a slight off topic
But does anyone know if you can fit the 330mm willwood fronts from an astra gsi?
e46 325i se - 1.8vvti avensis liftback
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Front discs
« Reply #8 on: 23 May 2016, 08:50:18 »
Would think, you will need a spacer, or different bells to fit.
Hoof'land storeman.
Re: Front discs
« Reply #9 on: 23 May 2016, 09:32:19 »
Different bells and a specific Monaro caliper...
That said, Baggedestate, whose name escapes me at this time of day :-[, found a fim that does Omega specific bells with various brake kits :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Front discs
« Reply #10 on: 23 May 2016, 10:06:49 »
Hi-Spec in Dartford will do all sorts of uprated custom brakes for sensible prices. Personally, I would be looking through the catalogues for an unmodified disc that is a bigger diameter/thicker than stock. Uprated discs are still consumable parts,  and having to modify them every time you replace them is best avoided. Then I would pick a caliper, as fitting that is the easy bit.
biggriffin
Re: Front discs
« Reply #11 on: 23 May 2016, 14:46:38 »
The easiest upgrade, is the one Mr teleporter had, which is the Monaro brakes, if you want to go HUGE, drop serek a pm he does an audi/porche conversion :o
Hoof'land storeman.
Re: Front discs
« Reply #12 on: 23 May 2016, 14:48:12 »
The easiest upgrade, is the one Pauls has, which is the Monaro brakes, if you want to go HUGE, drop serek a pm he does an audi/porche conversion :o
Fixed... uses standard discs... :y
biggriffin
Re: Front discs
« Reply #13 on: 23 May 2016, 15:16:12 »
Thank-you ::)
Hoof'land storeman.
Re: Front discs
« Reply #14 on: 23 May 2016, 18:01:21 »
Yup  :y
295x28 iirc...
All Omega discs are 2X6mm ;)
