Worth it for the low mileage?
Started by Ever Ready, 22 May 2016, 14:03:18
Quote from: TheBoy on 23 May 2016, 17:28:42
Quote from: Harris K Telemacher on 23 May 2016, 02:54:18
Best allrounder, for me, is the 2.6 :y
I'm sure you mean 2.5 manual ;)
Like the 3.0 over the 3.2, the 2.5 is marginally quicker and a damn site more economical than the 2.6...    ...and as you're going for the smaller v6, so economy is a factor, I've suggested manual, despite the Omega manual box being bloody awful :y
No worse than the average lorry. :)
Quote from: Doctor Opti on 23 May 2016, 18:31:23
You reckon? I've not driven any lorries with such a horrible box...  ...though the Omega box is simpler to understand than most larger lorries ;D
Quote from: TheBoy on 23 May 2016, 18:39:06
;D '04 Mercedes Actros artic with 800k under it's belt... needed both hands to change gear in low range when cold, and both hands and a foot on the dash to change gear in high range when hot... ideally would have used both feet, but you need one for the clutch... :D
Try a Mitsubishi Canter. It had 45miles on the clock when they gave it to me, and it ground the first 3 gear changes until the oil had warmed up which took about 5 miles. It was the same when the engine expired five years and 180,000 miles later.
We had a much older one that only one of us could actually drive; if you didn't get a down change exactly right, you had to stop and force it back up through the gearbox.
Omega gearboxes aren't slick, but then a high mileage BMW isn't any better.
ronnyd
If you want sh*t gear change, buy a Maxi. :P
Quote from: ronnyd on 23 May 2016, 20:02:54
Adequate only to get you as far as the dogging layby whereby you fold all the seats flat.. allegedly. ;D
Obviously no one has driven a Sherpa van ..... you knew the gear was in there ..... you just had to find it. It was like stirring a pan of porridge!  ;D ;D
ronnyd
Yeah, another BL pile of shite, and yes, the seats on the Maxi made a good bed. SWMBO and me camped out for a weekend in Sheringham, quite comfy but not much headroom. ;D
Quote from: Andy B on 23 May 2016, 21:36:55
I had a Sherpa luton type van briefly.  Whilst I recall its replacement (transit luton) a bit better, I don't recall the gearbox being bad.  Everything else was though ;D
